Question about Acer Aspire AS5920-6444 Notebook
Aloha....i just registered my new acer laptop. after "finish" a screen came up and i accidentally Xed it out instead of making screen larger. so.....how do i get the $100 of whatever that i was supposed to choose from? discounts on new stuff for registeringsoftware, etc. .... .................Mahalo, Margie
    Sergeant:
  • 285 Answers
Hello from the mainland! There is nothing good there and will just put you on marketing lists. If you want, you can look in All Programs for special offers, or something along those lines.
Posted on Mar 11, 2009
How do i unlocked my mini laptop?because its accidentally i locked.canyou pls help me?
You will need to factory restore, this will lose any stored data!
Start the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Dec 27, 2014 | Acer TravelMate Computers & Internet
Install oovoo
Changing the screen size on an Acer computer, whether it is a laptop computer or a desktop computer, is a simple task.
You can adjust the screen size to be larger or smaller.
If your eyes hurt from concentrating on tiny letters all the time, you should make the screen smaller.
If you have to scroll left and right to read sentences in a document on your computer, you should make the screen larger, at least to the point where you do not have to scroll left and right to view the entire window.
Go to the desktop of your computer and right-click the screen.
Click the last option, which is "Properties."
The "Display Properties" window will now show up.
Click the "Settings" tab in the "Display Properties."
Adjust the meter under "Screen Resolution."
When you move the meter to the left, the screen becomes smaller.
If you move the meter to the right, the screen becomes larger.
Click "Apply" to save the settings once you are finished adjusting the screen resolution.
http://www.marthas-web.com/display.htm
Jul 13, 2013 | Acer Aspire One PC Notebook
Acer aspire keyboard won't work
Try device manager in control panel to update drivers of keyboard.
Apr 12, 2013 | Acer Computers & Internet
How do i make my screen larger
start button
control panel
display icon
make adjustments
Jun 18, 2012 | Acer Computers & Internet
MwlDAEMON.exe failed to start Sysenv.dll was notfound. Brand new 5536G
This a known issue on Acers, especially if your running Windows 7. You need to uninstall and reinstall the MYLOCKER application, or just remove it of your not going to be encrypting files.
Oct 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
To replace broken screen on acer aspire 5735
First you need to get the right screen. Take out the screen by removing the rubber bumpers on the corners of the lcd bezel, then unscrew the screws that were beneath the rubber. After that you will have to pry slightly on the edges of the bezel to unsnap it and remove it from the laptop.
After that you will remove the screws on the sides the attach the screen to the hindges. On the back of the lcd it will give the model number, ebay is a good source for lcd screens. Once you get a replacement screen, you disconnect the cable on the back of the lcd and bottom, and then repalce the screen and assemble in reverse order.
Sep 01, 2009 | Acer Aspire 5735 Notebook
Broken screen
Hey how are you!!!
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
screen-not-working-3.jpg Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
screen-not-working-4.jpg The video cable has to be seated properly, all the way down.
screen-not-working-5.jpg Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
screen-not-working-6.jpg OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Good luck
ICmanServer
Aug 01, 2009 | Acer Computers & Internet
Blue screen on my laptop when I start reinstalling a deleted win Vista OS
I would get a different hard drive. Hard drives can be very tricky sometimes. I had that problem with My D600. replaced the hard drive and everything was okay. Hope that helps.
May 25, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire AS5920-6444 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
