Question about HP Compaq Presario C500t Notebook
Compaq c500 blank screen, can heard hard drive running
When i press the power button, the fan spins ( then i think it stops), i can hear something happening like the hard drive spinning, and when i put a disk in i can hear it spinning, but the screen just stays completely blank and the power button light continuously flashes really quickly.the laptop is a compaq c500, and it belongs to a colleague who is polish and i said i would try and find out what could be wrong.
  • 2 more comments
  • Lynsey2009 Mar 11, 2009
    thanks for your reply, are there any specific connectors that should be tightened? also, i forgot to mention, i tried it on an external monitor but nothing came up on that either
    ok, does this include connections on the motherboard? thanks for your help by the way
    I have been running it off the battery as i thought the battery was charged as the hard drive is running, ao i have only just realised that he has only given me half the power cable!i will have to get the other half from him tomorrow then give it a try. thanks! :)
    Its ok, i found the problem! i removed the cmos battery for about 5 mins, put it back in, and it worked! yay!
  • HP Expert
  • 285 Answers
You should replace the power supply, and clan out dust, and tighten connectors
Posted on Mar 11, 2009
  • Andrew Perrong Mar 11, 2009
    OK. Then it's definitly a power problem with the computer. You should tighten ALL connections by pushing together FIRMLY. If this doesn't work you'll need to replace the power supply.
    No, only the cables. Make sure you have discharged static by touching a Metal Chair
    New Friend:
Posted on Jan 14, 2013
  • 31 Answers
Posted on Nov 14, 2011
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
Have Acer L410 and it gets power and I hear the hard drive spinning but then you do not hear the normal hard drive sounds and it doesnt even get to bios screen nor any video. fans are running so I believe...
Sounds like it might be a Hard Drive Issue if you have heard any strange noise comming from the hard drive the Just think about replacing it with a new one .
If I can be of futher assitance feel free to contact me by posting on this page
Sep 12, 2011 | Acer Veriton L410-ED4450C PC Desktop
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
Compaq c300/c500 power on button, fan starts then fast blinking
what compaq use real models numbers clearly.
panel sounds desktop like.
ever heard of PC repair shop.
we have
1.1 Bilion Computers. on earth now.
guess what , vast numbers of shops with certified technicians
every where, on earth, were there are people.
is the screen dead, ? no text ever, and BIOS dead.
if a desktop the PSU is dead.
Jun 25, 2017 | Compaq Computers & Internet
Fast Blinking Power Button
Check your RAM. I had the same problem with my C500. I ended up having a bad stick of RAM. The only other cause I know of is the hard drive. Although this is rare if you had no problems with your operating system before.
May 16, 2009 | HP Compaq Presario C500t Notebook
Dead motherboard?
Try removing the memory one by one try that first if that does not resolve then It would be your motherboard.
thank you from Fixya
John C
Mar 09, 2009 | Compaq ( 277498-001) Motherboard
Computers & Internet Logo
731 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
