Question about Archos 404 Digital Media Player
Archos 400 won't turn on (error code 3)
I have an Archos PMA 400 and after i changed it's format to NTFS to put a file larger than 4 gb on it, it stopped turning on. I successfully put the file into a different computer but after that, the archos just won't turn on. A red screen shows up and says " error code 3, file system corrupted." I dont know what to do, please help.
    Problem Solver:
  • 24 Answers
I hard tried the same thing to transfer a 6.7GB file to another computer.I had formated the drive as an NTFS drive. when i turned archos back on, it failed to turn on give me error code. but for some reason it asked me to do a recovery. I remember i had seen some recovery files in my archos device saved (zipped file packages). And when it was doing the recovery i noticed it was reading the zipped files for recovery purpose. After the recovery, i did not see the files anymore in the device. So if i do the same thing again (format as ntfs) i might not be able to recover it back again.
Posted on Mar 15, 2009
Past a show to a external hard drive
When the file is larger that 2Gbyte you run into a problem, when the external drive is formattet in FAT. Larger than 4 Gb the Apple format stops you. Only the NTFS format allows you to save larger files.
Or when you make a DVD code from the show, It will fit on any drive, becasue the largest file on a DVD is onlt 1 Gb
Mar 06, 2015 | Apple MacBook Air
I cannot accesss my archos av400 20GB via usb. I tried different cables. If I select Hard drive, windows dont detect my archos at all but when I select windows device, my windows detect the archos but not...
Your windows is installed on FAT 32 partition, so it is not recognized partitions bigger than 4 Gb. Change to NTFS. ATTENTION ! All informations on your computer will be lost. Do this only after saving your private files !!!
Sep 11, 2017 | Archos AV400 Digital Media Player
Why can't I copy larger files than 4 maybe 5GB to my passport WD? Is there a quick way how I can change this?
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive:
-insert external drive
- open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System".
-click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
Aug 25, 2010 | Western Digital Passport WDXML800UE...
Error message if trying to save files larger than about 4GB.
The Buffalo Ministation hard drive comes with a default FAT32 file system. This file system is used for compatibility with Windows, MAC OS X, LINUX, etc. The file system does not allow files to exceed 4GB. To save larger files, the disc must be reformatted. For Windows, it should be reformatted to NTFS.
Jan 06, 2010 | Computers & Internet
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Archos pma 400 usb device does not recognise
Device drivers are not loaded or not loadwed properly.uninstall them and go to the web site and download new drivers.they should then recognize the player.RICHARDM69
Dec 17, 2008 | Archos PMA 400 (30 GB) Digital Media...
My Book 1Tb will not let me copy movies on to it.
To transfer files larger than 4GB to the drive, the harddrive must have an NTFS File system. Unfortunately, the FAT32 File system is not capable of handling a single file larger than 4GB (to be exact, one byte less than 4GB). Follow the steps below to format the harddrive with an NTFS File system:
Warning, all data on the harddrive will be lost! Please backup the data on the harddrive before proceeding.
  1. Locate My Computer (Computer in Vista). Right-click on the harddrive and select Format.
  2. Select NTFS from the File system drop-down list.
  3. Select Quick Format as the Format option and click Start.
  4. Note: If NTFS is not an available option, close the Format window and follow steps 4-9.
  5. Right-click My Computer (Computer in Vista) and select Properties.
  6. Select the Hardware tab and click Device Manager.
  7. Expand Disk drives and right-click on the harddrive. Select Properties.
  8. Click on the Policies tab and select "Optimize for performance.”
  9. Click OK.
  10. Repeat steps 1-3.
Nov 28, 2008 | Western Digital My Book Essential Edition...
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Archos 404 Digital Media Player Logo
308 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
