Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Built in speakers not regestering on computer
Monitor is plugged in properly to the back of the computer, and yet the speakers built in the monitor are not working. The computer doesn't even recognize it as speakers. The computer says there is no audio system plugged in.
Do you have a Sound Card installed in your computer, if not. Buy one at any local pars store. Now, if you have one installed. Then you must update your drivers or you are plugging your cable to a wrong output. Use the light green 1/8" connection.
Posted on Jun 19, 2009
I just bought an X223W LCD monitor for my computer and there's no sound. My previous audio cable has no place to plug into this monitor. How am I supposed to get sound?
Your previous monitor had built-in speakers. The Aces LCD monitor do not have built-in speakers, therefore you need to purchase external speakers and plug these into your computer.
Nov 18, 2010 | Acer 22" X223w LCD Monitor
I just bought the VN205N monitor. I am confused about the sound component. The store salesman says I have speakers in my monitor, but I do not have a plug at the back in which to put the cable in and the...
If it has built-in speakers then it will have on screen volume control, that is how you can tell if it has built-in speakers, I cannot find any info on this VN205N. You are better off using power speakers anyway with much better sound than the the monitor built-in speakers.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 04, 2010 | ASUS Computers & Internet
I just purchased an IBM L171 monitor for my desktop computer. I used to have harman/kardon speakers for my HP monitor, but I cannot find a plug on the IBM OR can't get sound if theyre built into the...
If the monitor has built in speakers, you will need to use an audio jack plug to plug into the pc's audio in ( green jack socket)
Otherwise just plug the speakers into the pc, not the monitor.
Aug 26, 2010 | IBM ThinkVision L171 17 inch LCD Monitor
How to use speakers
If your monitor has built in speakers then there should be a small jack in the back, usually green in color. You would need to run an audio cable from the monitor to the proper jack on the back of your computer, usually the green color like on the monitor. Once connected you should be able to use the volume button on the monitor to adjust to your preference. But remember external speakers are usually a higher quality than those built in to the monitor. Hope this helps.
Jul 11, 2009 | Relisys TL565 15" LCD Monitor
No sound from inbuilt speakers
this may be a second post since it appears that fixya didn't take the first one:
you should have a speaker cable in addtion to the monitor cable (big thick cable) coming from the monitor. the speaker cable (much thinner with similar plug as free standing speakers) needs to be plugged into the sound output jack on the back of your computer (jack is possibly colored green).
Mar 30, 2009 | Computers & Internet
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
Speakers - monitor E15T4
Every monitor doesn't have a place to plug speakers, does the monitor have speakers built in? You may have to plug your speakers up directly to the computer, imagine that!
Oct 25, 2008 | E-Machines eMachines Monitor E15T4
Nonworking speakers
For your monitor with built in speakers, there should be a cable usually the plug is green in color, coming from the monitor which needs to be plugged to the back of the computer for the speakers to work. If you don't see a cable, then there is a plug on the monitor where a cable would go.
Yes you can connect external speakers. They plug into the back of the computer. There are usually round ports on the back colored blue, pink, and green. Figure: http://www.ultimatepcrepair.com/files/bsound.jpg (sometimes there is more, depending on your computer) The speaker cable plugs into the Green color one.
If you need more help just comment.
Aug 14, 2008 | Proview PS 776 Monitor
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
Speakers
you need to ensure that the speaker lne cable is connected, this should be a double ended 3.5 jack plug cable, one end plugs into the back of the monitor, the other goes into your speaker port on the motherboard of your computer, sometimes there is a power cable required too
Oct 08, 2007 | ViewSonic OptiQuest Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
390 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
