Question about Dell Dimension 3000 PC Desktop
Dell Dimension 3000, ATI tuner issues
I have a Dell Dimension 3000 with Celeron. I installed a tuner (TV Wonder 100) a few years back. Recently I loaded some Microsoft upgrades and now I get an error msg when I open the tuner. It tells me to go to ATI to download updated drivers, when I do this it says the same error. When I do a system restore back to a time before the changes it works again, although it's always had some bugs.
Is there a way to upgrade software and/or drivers and not have this issue? Can I upgrade the tuner, or is my system to old?
  • Jim Brauer May 11, 2010
    you might want to try updating the tuner software before applying SP2 or 3, or whatever you're updating to. Also see if Dell has a chipset update for the motherboard.Do any and all hardware updates first, then do the MS Security updates. Can you give me a little more specs on your PC? Ie., AGP or PCIe. PATA or SATA. PC2100 or other memory type, processor speed, bus speed?
  • 81 Answers
I have an older ATI turner as well and the older cards do not work too well with Windows Xp or Vista. You may be able to find a driver that works by performing a Google search for it, otherwise the cards are very inexpensive right now and you can pick up a new one, probably with HD, for less than $100.
Posted on Mar 13, 2009
Honestech tvr
Use a regular TV to see if the analog channel is still transmitting. Maybe it is only in digital now.
Sep 30, 2013 | ATI Tv Wonder VE Tv / Video Input Adapter...
Installation of memory for del dimension 3000
what is the size of the memory that u r tryin to install
Nov 26, 2010 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Can't download DVD DTV decoder for ATI wonder VE card.
ATI should give you the software in a zipped file as a free download. If they do, then save it to your desktop, and later, when you go to install it, unzip it to a file. It should install. Just choose the support and download section on the ATI site.
Sirwriter
Nov 11, 2009 | ATI HP/ HDTV Wonder VE Capture Card With...
Dimension 3000, ATI TV Wonder 100 issues
Since you already tried to go to ATI to download the latest drivers, do this:
Go to control panel, and administrative tools.
Click on the event viewer and check out the system logs (click on system) and look for entries on the right side with a red X.
These will probably give you a clue just what part of the sytem is having a problem with the card.
If the problems occur when you use an application and not in Windows generically, click on the application logs and see if there is a problem there.
Be aware that this may take some sleuthing--the error messages are not always clear, but many times you can click on the link that takes you to Microsoft and they suggest what you can do.
Mar 11, 2009 | Dell Dimension 3000 PC Desktop
RAM
You may have bad or incompatible Ram . Verify that the memory you have is compatible. .
Machine name: Dell Dimension 3000
CPU options: Intel Pentium 4 or Intel Celeron
Chipset: Intel 865GV Chipset
HD Bus: Ultra ATA/100
Front Side Bus options: 800MHz FSB
Memory Speed options: PC3200 DDR400 184pin SDRAM DIMM
Special notes: The Dimension 3000 has two different bus speeds each of which takes different memory. You cannot mix the speeds.
Take the memory out and install one at a time. This way you can verify that the memory is indeed working. If you find a bad one, replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | Dell Dimension 3000 PC Desktop
Media Center can't find digital TV channels for TV Wonder HD 600
Just to make sure, you do have analog tuners setup right?  Media Center 2005 requires analog tuners be working before digital tuners are allowed.
Oct 11, 2008 | ATI TV Wonder HD 600 PCI PC TV Tuner...
TV Wonder 650 USB
i am not able to remove the ati remote wonder 1.4 software from the control panel method as described bsn
Jul 08, 2008 | ATI TV Wonder PRO Remote Control Edition...
DELL PART # DN804 For E521 computer
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
May 03, 2008 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Should I get a new cpu for dell dimension 3000?
HII MARLBOROMANZ ,
YEAH THE PROCESSOR IS BIT SLOW FOR GAMES TO RUN PROPERLY.
I WOULD SUGGEST U TO BUY MOTHERBOARD THATS INTEL 965G AND CORE2DUO PROCESSOR.
U DONT NEED TO UPFRADE THE RAM AND VIDEO CARD U CAN USE THEM IN NEWLY UPGRADED MOTHERBOAD AND PROCESSOR.
I AM SURE U WILL ENJOY GAMES IF U UPGRADE ONLY OTHERBOARD AND PROCESSOR.REST ALL IS FINE.
Nov 03, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
81 people viewed this question
Alun Cox
