Question about Sylvania LC-200SL9 20 in. LCD EDTV
I can't scan to set up channels on TV
I click menu, I use the channel down button to get to "set channels." I want to scan the channels because they have all changed due to HDTV, but any other button I touch next makes the control panel shut off. I can't scan. Suggestions?
20 inch flat panel Sylvania TV
SOURCE: Sylvania 6620LCT 20
throw it in the landfill there are no replacement parts.
Posted on Nov 02, 2007
Agent Aaron
  • 265 Answers
SOURCE: programming channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 20, 2008
SOURCE: Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Posted on Sep 09, 2008
  • 19 Answers
SOURCE: loses channels when shut off. must auto program
Your may be in shop mode, I'm not sure if Vizio's have a service menu. Go to setup and go through the install process again, watch for a demo or shop mode setting. If there isn't a setting then you need a new mainboard
Posted on Mar 22, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
I do not know how to do a channel scan, can you help me please? I seriously thought that I could find anything online but I have not been able to find how to channel scan this tv.
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
(low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
Apr 29, 2011 | Televison & Video
I hook my antenna to the back and I'm not receiving a picture
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
Dec 30, 2010 | Curtis LCD2424A 24 in. LCD HDTV
Toshiba tv 32kv500b, when tryin to install channels came up no signal, checked aerial cable but cannot get back to the installation menu which came up in the beginning, when press menu button a smaller set...
I suspect you are seeing the Main Menu for the source that you are currently using. Press the Source button (TV/AV on the TV itself) and make sure you are on TV source. The menu will have a set of icons if it is set for analog and a vertical list in digital. Select Setup (use the up/down arrows for digital and the left/right for analog - it's the first one in the list) and click OK. Then select Installation (third one in the list) and then press OK. Next select Automatic channel scan (first one again) and press OK. You will see a warning prompt, highlight Yes and click OK to scan for digital channels. When it is done, it will ask if you want to scan for analog channels.
The manual is available here: http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/KV500-32-English-Specific.pdf (direct link to the pdf)
I hope this helps.
Dec 16, 2010 | Toshiba Televison & Video
VIzio channels won't change
press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
Sylvania LC-200SL9 20 in. LCD EDTV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
