Question about Gateway 3545GZ PC Notebook
My power adapter gets extremely hot
My power adapter for my gateway laptop gets very hot. So hot that I have to unplug it even if the computer is not charged. I am very concerned this could be a fire hazard. Cannot find any recalls on this power cord
    Scholar:
  • 54 Answers
I agree that it could pose a fire hazard if allowed to get too hot. Contact Gateway and ask if they will replace it, especially if your computer is still under warranty. If you're no longer under warranty or if they refuse to replace it for you, new power adapters can be purchased for $30-100, depending on make and model.
Below is a link for your power adapter at Buy.com:
http://www.buy.com/retail/product.asp?sku=209135212&listingid=38673486&dcaid=17902
Hope this helps.
Posted on Mar 11, 2009
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
Tip
How to reset Gateway Laptops
Unplug your gateway computer, pull the battery out of you computer, Hold the power button down for 60 seconds, it might not take this long, but better safe than have to go back and do it again. Release power button, install battery, plug in ac adapter, then power on. This helps to recognize new batteries and start up problems do to new hardware installations.
on Mar 06, 2010 | Computers & Internet
My Gateway computer is plugged in but not charging. The ac adapter is brand new. Why?
Try this- Unplug the laptop, take out the battery, and hold the power button down for 30-45 seconds. After that, put your battery back in, plug in the AC adapter and turn it on. It's usually the solution in your type problem
Apr 18, 2011 | Gateway MX8711 Notebook
My laptop is a gateway Model:MC7801u. I have had it since 2008 and have had constant problems with the ACadapter and battery. It randomly decides not to charge my battery and then my battery dies and the...
Some people have successfully reset the charging system with the following procedure:
  1. Shut down the computer
  2. Close the lid
  3. Unplug the AC adapter
  4. Remove the battery
  5. Plug in the AC adapter
  6. Open the lid and turn on the computer
  7. Log in to your user account as usual
  8. Shut down the computer again, and close the lid
  9. Unplug the AC adapter
  10. Put the battery back in
  11. Plug in the AC adapter, open the computer and start up again
The battery should now charge normally. If this process needs to be repeated any time soon, the small clock and parameter backup battery inside may have gone bad. I don't know where that is in this particular model. In some designs, it's accessible from the wireless card or memory compartment; in others it's somewhere under the keyboard.
Charging failure can be the result of a broken cable in AC adapter, often caused by yanking on the cable to unplug it rather than pulling on the plug body. Sometimes the adapter jack gets worn out or the solder connection inside the laptop breaks. In these cases, usually no light comes on when you plug in the adapter or the AC power indicator light is intermittent.
Also, if you have a Sanyo battery pack there are some issues with the battery management firmware. Gateway has a BIOS update to address the problem.
Apr 15, 2011 | Gateway MC7801u Notebook
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Gateway M305 power adapter replaced by Gateway. Now blue screen
Try running it just on battery. Then take the battery out and just run if off the adapter. see what happens..and call Gateway and complain..if it doesn't run off the adapter then you really need to call gateway..cause you're stuck without a working computer.
Mar 22, 2009 | Gateway M305CRV Notebook
I need a power adapter for my nascar pc notebook.
The reason why the adapter is running extremely hot is that either it is faulty and it's capacity too low for your laptop requirements.
Check the voltage and current requirements of your laptop, it is printed on a label on the bottom ofthe laptop.
The power adapter you require should be the same voltage and current (amps) or higher current rating that what is printed on the laptop label.
Jan 07, 2009 | ZT Group NASCAR M2002 Notebook
My ac adapter heats up & gets extremely warm.
As long as it doesnt burn your hand or start smoking ...don't worry about it. All laptop "bricks" get hot .... no cooling inside there ...
Jan 03, 2009 | ASUS AC Adapter- Universal Notebook AC...
Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Jul 12, 2008 | ASUS Computers & Internet
Gateway 3545GZ PC Notebook Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
