Question about Weller TC201T: Soldering Iron For Wtcpt, 42 Watt
Hi! I need the female end of the connector that the soldering iron itself connects to the base for a Weller WTCP soldering station. This is a black connector, and I need the female part that mounts in the base. Also, how do I get the base apart? Screws under the rubber feet? Thanks! Bill B.
  • PolyrhythmFX
    PolyrhythmFX May 11, 2010
    You mean the female plug on the soldering station itself? If so, yes you would have to take it apart via any screws on the enclosure.
  • 202 Answers
Bill, i would use a connector with the correct number of ends made for a radio. you could probally find them at radio shack. be sure to connect the right wire to the right pin on each. you would need male and female. then the next question is yes four screws under the rubber feet
Posted on Jul 07, 2009
I have Weller EC1002, WES51, and WTCPS all with base, cord, and handpieces (complete). On shelf for years. Can you test, quote and do repairs as needed?
yes but shipping alone would eat a lot of $$$
they r pretty basic - u should be able to do that urself.
a multimeter may be necessary
it is either
broken wire in cables
bad connection inside case
thermal cutout
bad tip
switch.
Jun 30, 2014 | Weller WES51 SOLDERING STATION
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
I have a weller EC1201A iron connected to an EC2100D base unit. It is a UK 240V model with digital temp set and display. The iron does not heat up. You can set the desired temp but the display just...
its my be the controler
http://cgi.ebay.com/New-weller-control-Board-EC1002-soldering-stations-/390286420305?pt=LH_DefaultDomain_0&hash=item5adee22951
good luck...
Feb 25, 2011 | Weller Welding Tools
The solder station (power unit) is turning itself off randomly
I have heard that some of these had a failure on the regulator circuit that was packaged on a ceramic substrate with the control pot. Not sure if yours is this type.
Jan 17, 2011 | Weller Wesd51 Digital Soldering Station...
Unit does not heat up to temp and green light blinks
hi, i have faced the same problem with my station also. the issue will be only with your 6 pin connector, check whether all the pins are getting connected properly. some times when u apply force the connector's pin may go inside. check up with that.
Nov 04, 2010 | Weller WES51 SOLDERING STATION
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Tip for weller soldering station wtcp-s
The #7 indecate a operating temp. of 700°F
It is problay the thermostat contacts that needs burnishing, that should fix it so that you don't have to buy a new heater / thermostat. Their parts are expensive.
Apr 03, 2009 | Cooper Industries Weller Field Soldering...
Weller TC201T:  Soldering Iron For Wtcpt, 42 Watt Logo
218 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
