Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
My thread gets stuck down in the bobbin area.
I'm learning how to sew. My thread is getting stuck down in the bobbin area. Then my material gets stuck pulls towards the teeth.
    Novelist:
  • 97 Answers
Ensure that you are threaded correctly, set your tension for roughly 4.5 and "floss" your machine when threading by grabbing the thread by the needle immediately prior to threading the needle with your left hand, and the thread on the top by the spool with your right hand; then pull the thread back and forth briefly.
Ensure that your bobbin is in the bobbin case in the correct orientation.
Ensure that your feed dogs are in the "up" position. Many inexpensive machines do not have the option to drop the feed dogs, and I believe your kenmore to be one that lacks the option, but consult your manual just to be sure.
Also make sure you're using a good quality thread. Use a European thread, and definitely avoid anything from the dollar bin or any kind of "dual duty" type thread. Cheap thread causes nasty nasty things to happen to sewing machines.
If none of these fixes solves your problem, let me know; but going through the above will solve 99% of problems like you're describing.
Good luck,
-R
Posted on Mar 11, 2009
  • kristine264
    kristine264 Oct 11, 2012
    yes I have done these things and the thread is still getting stuck,Does this have Anything to do with pressing the pedal with out the foot being down?
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
When I am sewing, somehow the material gets caught in the bobbin area. The thread becomes entangled there and pulls the material down with it. How can I fix this?
Make sure when you thread the machine, that you have the presser foot (the foot that rides on the fabric) in the 'up' position.Also make sure you get the thread down between the discs of the upper tension. Set the tension on '4'. Usually when you get thread bunching up below it's caused by improper threading of the upper thread.
Hope this helps!
Bob
Jan 31, 2011 | Euro-Pro Sewing Machines
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
Extra piece of thread in bobbin compartment after sewing a few pieces. Its a brand new machine, with drop in bobbin. I am sewing on minke fabric with a quilt batting inbetween. I tried adjusting various...
I am not sure I am following your explanation.
Set the tensions back to the factory setting.
Refer to the manual for threading instructions.
Always thread a sewing machine with the presser foot up.
Make sure the bobbin is inserted so the thread is feeding from the bobbin spool in the correct order and through the proper guides.
Hand-walk the needle down and back up while holding onto the end of the thread.
Pull up the bobbin thread and take both threads under the presser foot and to the back of the machine.
Always take the threads toward the back of the machine when you begin a new seam.
This may, or may not be contributing to the problem, but the materials you are sewing shed a lot of lint and the bobbin case, shuttle and surrounding area new frequent cleaning.
Mar 06, 2010 | Kenmore Sewing Machines
My material gets stuck in
check and see if the feed dogs are above the needle plate when the needle is in the upright position, then check and see if you have tension in the upper and lower tension units, check this by putting the foot down and gently pulling on the upper thread and pull the lower thread up through the plate and see if it pulls easy or hard if hard then it is good one last thing are the feed dogs in the raised position
Oct 17, 2009 | Sewing Machines
Bobbin area will not work
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Jul 17, 2009 | White Sewing White 3032
I have euro pro 9106 sewing machine. When I try to sew the
Make sure your needle is in the down position in the material and hold on to the tails of the top and bobbin thread when you begin sewing.
Dec 24, 2008 | Euro-Pro 9000 Mechanical Sewing Machine
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
2,021 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
