When printing the page has light dot on left hand side of page after putting in new toner.
You answered your own question. It is, the in all likelihood, toner cartridge causing this.
Posted on Mar 11, 2009
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
What can we do about dark toner spots that are appearing on the right side of documents we print? We have tried using a can of air spray to clean the inside of the printer, but to no avail.
I have a Brother HL 4040cn color laser printer and I had the same problem. On every page I printed there were these black dots that appeared down the right side of the page in regular intervals. I tried the automatic drum cleaner and that didn't work. I opened the printer from door, removed the black toner cartridge and looked at the drum. Sure enough there was a speck of black crusted toner stuck to the drum. I used a q-tip and lightly scrubbed at the spot to remove the toner then I used the gear on the left side of the drum to rotate it and check for any other smudges and there were none. Put the toner cartridge back in and it was good to go again...no black dots!!
Hope this helps someone because I couldn't find the solution myself when I searched.
Sep 22, 2010 | Brother Office Equipment & Supplies
Toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 01, 2010 | Brother HL-2040 Laser Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
11 blue dots print out down the left hand side of documents
it sounds like the CYAN toner cartridge is leaking.
Jan 22, 2009 | Office Equipment & Supplies
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Hp 1320 wont print
i think you might consider checking the toner on your printer, i.e. replace the cartridge...
hope this helps
Apr 09, 2008 | HP LaserJet 1320 Printer
Scattered dots on the left side of page
replace toner cartridge or toner drum
Feb 27, 2008 | HP LaserJet 1020 Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
My laser color 9420
Sometimes when toner starts to get low prints will faed or not print on sides. Make sure the printer is on a very level surface. Remove the toners and shake lightly left to right and reinstall.
Aug 09, 2007 | Brother MFC-9420CN All-In-One Laser...
56 people viewed this question
jasbo
jasbo
