Question about Sony DRU 510A DVD±RW Burner
Sony dvd rw dru-510 doesn't work, the light is just flashing
The tray won't open by itself
SOURCE:
shriii
  • 65 Answers
SOURCE: SONY DVD RW DRU-830A "d:\ is not accessible. Incorrect Function."
generally d cd,dvd writer or cd,dvd player of SONY creates dis problem it is unable to read local disks due to high sensitivity of dere lenses...
i hv seen in many cd,dvd writers havin dis type of problems...
it can not made....
but i would prefer u to use LG cd,dvd writer which is capable of readin all local or orignal disks..
Posted on Jun 19, 2008
SOURCE: Sony DRU-820A DVD RW Dual Layer Burner not working
Here's the first thing Sony says on the subject:
Ensure the Sony drive is set as a secondary master by itself. If you have another disc burner or a zip drive on the same IDE cable, please separate them.
My MSI P45D3 has a single IDE channel...
ARG!!!!!!!
Posted on Feb 22, 2009
Muzzi_123
  • 749 Answers
SOURCE: Sony DVD RW (Model DRU-840A) Drivers
Hi, here are the firmware/drivers/utilities to your sony dvd drive.
>>>>Link<<<<
Hope This Helps
Muzzi_123
Posted on Jul 16, 2009
  • 166 Answers
SOURCE: Sony DVD RW DRU-830A won't finalize
the problem might be in your dvd writer.
Posted on Sep 16, 2009
  • 4 Answers
SOURCE: Sony DVD RW (Model DRU-840A) Drivers not found on
ABDUAALH POST http://codeguys.rpc1.org/firmwares/sony/dvdrw/stock/840A.SS01.stock.rar
Posted on Apr 04, 2011
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Disc tray won't open
Open a paper clip and push one end into little hole next to disc tray. push hard, the tray will open.
Jul 19, 2012 | HP Pavilion a1640n (RC663AA) PC Desktop
My 360 kinect won't read disks. It says open tray,
my x box 360 Kinect want work because when I put the game in it said open and close the tray
Apr 08, 2012 | Video Game Consoles & Games
Tray won't open
Make sure nothing is blocking the path of the tray or that nothing is stuck.
Mar 29, 2012 | Video Game Consoles & Games
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Sep 19, 2011 | JVC DR-MV7S DVD Recorder/VCR
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
360 tray opens and closes by itself
broken faceplate or broken dvd tray. Call MS support.
Mar 20, 2010 | Microsoft Xbox 360 Console
Open Questions:
Sony DRU 510A DVD&#177;RW Burner Logo
171 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
