Question about HP Pavilion dv9000z Notebook
My laptop works off battery but not off the dc power
My laptop will not work when the adapter is used. I purchased another adapter, but the new one does not work either. What are possible problems with solutions
    Sergeant:
    Champion:
  • 357 Answers
Is there a light on the adapter and is it on?
Remove the battery and see if the adapter powers up the laptop with the battery removed.
Install the battery, connect the adapter and see if it works.
I hope this helps and resolves your problem.
Good Luck.
Posted on Mar 11, 2009
Notebook woks on battery but does not on power supply
Hello. It sounds like either...
1. Your Asus power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 10, 2012 | ASUS (F50SV-A1) PC Notebook
I got a new battery it worked when i got it now it wont charge ac adapter works though after i made sure the battery worked i put the computer away for a present for my daughter i have my own laptop so the...
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 17, 2011 | Gateway T-6321 PC Notebook
Battery light is blinking red and will not charge
Welcome to Fixya! If the battery light is blinking red,that indicates low power, there's a possibility that the problem is with the AC adapter, or the battery or maybe the DC port itself, please follow these simple steps for you to be able to isolate the exact problem.
Feb 28, 2011 | Panasonic Toughbook CF-73 Notebook
Advent k200 laptop does not charge new battery
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
My laptop battery doesnot working.and the laptop suddenly shuts down whenever the external power is gone.now my laptop does not working.whenever i pressed the power button it boots up and then shuts down...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 13, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
My hp compaq laptop charger is not working in the charging port but the laptop work's when the battery is charge and place in the laptop how to use the external battery port
DC Jack diagnosis:
Sep 22, 2010 | HP Compaq NC6400 Business Notebook
Notebook won't power on
Take the battery off and try to turn it on with just the power cord. If it works then it's your battery. If it doesn't then it's either your ac adapter or your dc jack. Try an ac adapter from a local pc shop or electronics shop. AC adapters run around 40 dollars or less if you order them online. DC jacks are a different story. I the jack needs to be replaced you'll have to take it to a pc shop or if you can do it yourself then order a dc jack online or purchase it online and take the computer apart replace the dc jack (you'll have to desolder the old one and solder the new one one). Good luck!
Aug 23, 2010 | HP Compaq nx8220 Notebook
Why does laptop stop working through adaptor after battery flat
Hi There,
Your battery charger/adapter connects to the DC Power Jack to power your laptop and charge the battery. Since the charger/adapter does 2 things, there are 2 "cells" inside it to do those 2 different things. It's not uncommon for one or the other (but not both) to fail. So, often just purchasing a new charger/adapter solves the problem you're having. It appears that yours is continuing to charge but has stopped "adapting" AC current to DC current to power the laptop directly.
Jul 10, 2010 | Computers & Internet
Dell 2650 DC wont work
make sure the charger you purchased has the correct voltage out and amperage(in millivolts) as requested by the laptop computer, if not you risk the chance of damaging your laptop. although they fit in the power plug, it does not mean theyre compatible. The specs should be located at the bottom of the laptop or inside the battery bay.
Apr 01, 2010 | Computers & Internet
No DC Power To Laptop
The problem is the input power socket on the laptop. It is either damaged, or the soldered connections on the connector has disconnected from the motherboard (eg formed a dryjoint).
It should not be too expensive to repair, or you can pull apart the laptop yourself and resolder the power connections. I suggest you use a temperature controlled soldering iron and ground yourself with a static strap for this repair.
Jan 07, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
