Question about Office Depot Ativa DQ60M Shredder
Need blade for Ativa DQ121md - Office Depot Ativa DQ60M Shredder
  • Anonymous Mar 26, 2009
    My blades are kaput also...one, measly credit card bent all of the blades in the center 2-inch section. Help...
2 Suggested Answers
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
Ativa shredder manual
Are the shredder blades going around? most shredders have guides that guide the paper between to shredder gears or teeth. these guides are usually made of plastic and breake. First step is to see if the shredder gears or teeth ar going around.....
Sep 23, 2013 | Office Equipment & Supplies
I just need to know how to oil the Ativa AT1250 shredder. We no longer have the manual. Is there a specic "well" to place the oil into or is it just spread across the blades.
Just use regular "shredder oil", if you hav'nt put any oil on in some time pour it directly onto the blades....once in a while put the oil onto a sheet of paper you are going to shred and shred the paper with the oil on it.
Nov 15, 2010 | Office Depot Ativa 1250 (MicroCut)...
Does the Ativa CX12W need lubricating,and if so how? I don't see anything in the manual?
Yes!
3-in-1 or Marvel Oil will do just fine.
Start the shredder and squirt a generous amount of oil down back and forth into the feed slot to soak the blades.
Sep 28, 2009 | Office Depot Ativa CX12W Shredder
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
XF50D motor won't turn shredder blades
There is no viable solution.  There are no replacement parts available.  The Office Depot shredder is a cheap low quality product made by a cheap company.  The FIXYA service agreement costs more than the product.  Bad choice to buy the product!
Dec 07, 2008 | Office Depot Ativa DQ60M Shredder
Ativa shredder
Pull out as much of the paper as possible. Then spray some window cleaner or similar on whats left to soften and disolve it.
Dec 29, 2007 | Office Depot Ativa DQ60M Shredder
Ativa dq60m
The main problem with paper shredders is tha t they don't get their proper maintenance...
They should be lubricated (If you open the door, you will probably find a small bottle with lubricating oil inside the cabinet). Look inside the supplied manual and follow the instructions.
I tell this because one of my friends has business with paper shredders, and the most common cause is missing maintenance and/or lubrication.
If it's the blades in the center that cause the problem, this points to a worn out wheel that hasn't got the proper lubrication.
The solution is to get a new shredder, or if your shredder is of a known brand, get a new set of wheels.
Oct 12, 2007 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
156 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
quennie732
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
