Question about Samsung HL-R5078W 50" HDTV
Immediately Shuts off with blinking light codes
Can anyone explain the codes for the following blinking lights:
Green flashing lamp
Red Flashing Standby
When the tv is powered on it starts, lamp lights up and I can see the menu but within seconds its shuts itself down and display the above light configurations. Any help would be greatly appreciated on this.
  • mcarpani Mar 11, 2009
    Thanks, I have tried many google searches but have yet to find anything that references the blinking lights and what they stand for.
  • mlhutchco May 03, 2009
    I have exactly the same problem!
  • 40 Answers
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Posted on Mar 11, 2009
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Rca tv L46WD22 and green light followed by 5 red flashing lights
These blinks (Flashes) are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check these link s
http://electro-medical.blogspot.com/
Dec 13, 2013 | RCA L46WD22 Television
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
Flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
May 19, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Mar 14, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Samsung HL-R5078W 50" HDTV Logo
338 people viewed this question
Jerry Greenberg
Jerry Greenberg
