Question about Rowenta DZ9080 Iron with Auto Shut-off
Iron leaks water
Less than a year old and leaks water from bottom of iron, has never been dropped.
  • Rowenta Master
  • 43,501 Answers
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
My iron is leaking water. Can it be repaired? I picked it up off the ironing board today and it was sitting in a puddle of water. It continued to pour out the bottom. Is this fixable?
I have had several do this after many many years of use. I did not find a fix but ended up buying a new model. If you do not need to use the steam function, you can still use it. Might want to use a spray bottle with water to add the steam the old fashion way.
Jan 27, 2014 | Irons
I was using my B & D D 6000 All Temp Steam Iron - it is only a year or so old and... without warning it shut off...dead...nothing....will not turn back on...it was not dropped and I am ot aware of any...
If less than year old it is under warranty. Otherwise the heater element may be open. If you take to small appliance store for repair it might cost more than a replacement.
Sep 15, 2017 | Black & Decker ICR200 Iron with Auto...
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
Jul 14, 2010 | Rowenta Power Duo Iron
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
When I first begin to iron, water comes out in wide streaks on the garment Sometimes the water will leak out the bottom of the iron, not from the plastic container, but out a crack in the metal part on the...
It sounds like the iron that I had about 8 years ago. I would return it before the warranty runs out and get your money back. I would recommend a phillips G4430. you will love it
Sep 09, 2009 | Rowenta Irons
I have 1700W Rowenta Focus and it is fairly new and water won't stay in it. I pour water in and leaks out all around the sole of the iron. What is going on? It never has been dropped, fallen off anything...
Possibly one of two problems.
1. Water tank has a hole in it.
2. Filler tube that go's into tank has come off.
If you are handy and have the correct type screwdriver bits, you may be able to open the iron and have a look.
Other wise it's bite the bullet and buy a new one. Wallmart or similar do some quite good cheep electrical stuff.
Aug 06, 2009 | Irons
Water pouring out of my iron
heatman101
Aug 26, 2008 | Rowenta Powerglide DM273 Iron
G6118 Euro-Pro Iron
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it
good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up
the vinegar concentration but do not go higher than 2 cup to 1.
George
Mar 14, 2008 | Euro-Pro G6118 Iron
Rowenta DZ9080 Iron with Auto Shut-off Logo
1,349 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
