Need to get audio device back into computer
We have no sound on our computer, we have the Creative Inspire T3030 sound system, it used to work fine but now we have no sound at all an when we tried to troubleshoot, when we go into the sounds and audio devices, it says no audio device, we may have deleted it by accident when cleaning off a bunch of other unwanted stuff. How do we get it back, everything is still plugged in like it should be. Please Help
  • 50 Answers
First you should check to see if the audio card is in the Device Manager. If not, try shutting down, unplugging power to PC open case (only if your comfortable doing so), physically remove the sound card and re-fasten it in the respective slot. Reconnect power and go into the BIOS. Once in the BIOS, get to the section of integrated peripherals, and disable the on-board audio. Save and exit, then let it boot up. If you get no "Found New Hardware", open the device manager and see if the card appears in the list. At this time if there is a question mark or an exclamation point, you have either a hardware conflict or an unknown device. If you don't have either of the symbols next to the audio card in the list, try opening your audio properties again and see if the card has returned to the software. If the device is not there, but is on the list in Device Manager, try re-installing the software it came with. If you have the other issues with the symbols and re-installing does not work, there may be something more than what may be the obvious.
Posted on Mar 11, 2009
Hi. where can I download creative inspire t3030 driver for mac?\ Tnx.
Surprisingly, drivers aren't actually required for that model!
Aug 20, 2011 | Audio Players & Recorders
My speakers just for some unknown reason aren't working.The remote control won't light up anymore
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
if you don't have the drivers you will need to download them
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html
Jun 29, 2011 | Creative Labs Inspire T3030 Computer...
Ok, so I have had creative inspire T3030 2.1 speakers for more than a year now, but recently I noticed slight cracking and popping sound coming out of the left satellite speaker. I tried swapping them and...
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 12, 2011 | Creative Labs Inspire T3030 Computer...
T3030 speaker system with wired remote.was using headphomes..removed them and now no sound from speakers.all lights on..no sond
if you are having problems with your sound
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Mar 27, 2011 | Creative Labs Inspire T3030 Computer...
I've got a used creative inspire t6060. Connected all, no sound. There's green light on the remote wired control, power supply measured fine: 18.5V AC from transformer, and also 18.5V DC at the big...
also
hope this helps
Mar 17, 2011 | Creative Technology Inspire T6060 5...
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
Creative Inspire T3030 speakers not working
hello
I have creative inspire T3030 ,dont function ,Iwant help
Mar 31, 2009 | Creative Labs Inspire T3030 Computer...
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
