Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Polaris 280 rear wheel does not turn
The rear wheel does not turn, nor does the small wheel between the two wheels. Need help.
Back wheel does not drive. What can it be?
Posted on Jun 10, 2011
Polaris 280 wheel tilted
see if inside wheel mount broken or loose
Jun 10, 2012 | Polaris 280 In - Ground Pool Cleaner with...
My wheels are not turning on polaris 280
Make sure that your thrust jets are properly positioned. You will also want to check for any obstructions in the wheels or axles that would restrict movement. Often with these automatic pool cleaners, one of these two problems is causing restricted movement in the wheels.
Jul 02, 2010 | Polaris 280 In - Ground Pool Cleaner with...
My wheels are not turning on my Polaris 280, what can I do?
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
Jul 27, 2009 | Polaris 280 In - Ground Pool Cleaner with...
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 280 flow is low and moving slowly with nosedive mnmc660 yahoo com is my email. seems like tale spray is fine but rear spray output and wheels turn slow resulting in nosedive. alkready checked...
Make sure that your skimmer, pump, and pool filter are clean and working properly. Your automatic pool cleaner can become sluggish if anyone of these features of your pool is not working correctly. Check all the hoses, connections, and swivels for leaks that could cause loss of water pressure. If it has been working poorly since you replaced the booster pump, you will also want to make sure that it is installed correctly. Finally, check your wheel RPM. It should be operating at between 28-32 RPMs. To do this, mark a single wheel side tire. Turn your pump on, hold the cleaner underwater and count the wheel revolutions for one minute. If you are under 28 RPMs, this might be your problem. To correct this, check your filter screen. I know thay you said that you have already done this, but this is typically the problem so I would check it again. Also, you can remove the blue restrictor disk from the UWF. If you booster pump has an open gate valve, open it completely to increase water flow. This will also help with your RPMs. If you try these suggestions and they do not work, let me know and I will come up with something else to try. Hope this helps you out.
Jun 06, 2009 | Polaris Vac Sweep_ 280 Pressure Side In...
Polaris in pool cleaner back water single spout not water passing
Check your wheel RPM. With these automatic pool cleaners, you can manually adjust the RPM. Low RPM could be the cause of the problem. To check the RPM, first mark a single wheel side tire, Turn the pump on, hold the cleaner under water and count the wheel revolutions for one minute. If the RPM is less than 28, you might need to remove the blue restrictor disk from the UWF or adjust the gate valve on the booster pump. Also, this may sound simple, but make sure there is no debris lodged in the wheels/axles. Check your filter screen in your in-line filter and make sure that it is clear of debris. You will also want to check your hoses, connections, and swivel to make sure that there are no leaks.
May 31, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Front wheels don't turn
It's probably a damaged drive gear. Polaris was at one time giving out free repair kits for this problem because of the poor design of the original.
Apr 18, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
752 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
