Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi 725R fuel filter; How is it re-mounted? Fuel line is soft and weak > tears easily. I am replacing the fuel lines and need to re-mount the fuel filter into the tank. It seems next to impossible to get the filter stem,(with line attached), through the hole in the tank. I have managed to get the stem through and about 1/8" outside the tank surface but isn't there about another 1/8" more to go? Ryobi couldn't have made this re-mount easier?
  • Anonymous May 14, 2009
    I have the same problem ,but i let a family member use my ryobi and all the fuel line are off . can you tell me were they go.
  • 40 Answers
After you insert the fuel line through the tank and install the filter. take some WD-40 and spray the hose. now from the bottom of tank the pull on the hose. and just keep pulling on it till it comes through all the way. then slide the little white washer back over the hose and seat in place. this should do it for you. they are a royal pain in the **** to work on. numerous brands of string trimmers have these top mount tanks. a new tank with hoses already assembled is about 45 bucks with shipping. much cheaper to fix it yourself.
Posted on Mar 11, 2009
To tombones49.
Can you look at my post about my Suzuki GS550L?
I don't know how else to get hold of you.
See link below.
Thanks
http://www.fixya.com/motorcycles/t12598170-1980_suzuki_gs550l_idle_speed_adjustment?eventid=21532657
Posted on Apr 29, 2012
How do you get the fuel line connected to the fuel filter nipple on the bottom side of the gas tank on the Ryobi 725r gas trimmer?
You must run the fuel line through the back of the tank and out the filler hole,make your connections,i used a small amount of vaseline to make the connections.Then pull the filter into place,make sure some of the nipple of the filter pokes through,then slide the retainer ring on the hose and force it onto the filter nipple.
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 725r leaks gas from air filter and will cut out after starting up
This is a problem with most ryobi tools. From what i've read over time the gas lines shrink and need to be replaced. You'll need to replace both the lines coming from the carb to engine and the one connecting to your primer bulb. I hear there is a kit that contains both the primer bulb and fuel lines for this exact problem.
Apr 21, 2010 | Ryobi Garden
Need a diagram on how to connect the fuel lines back on a ryobi 725r trimmer
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Oct 01, 2009 | Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel line routing for RYOBI Models 705r and 725r
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Garden
Ryobi 725r Fuel Line replacement
form a gasket silicon gas resistent at any auto parts store about $6
Jul 06, 2009 | Ryobi 15" Electric Factory Reconditioned...
RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Jun 13, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
I need to know how the fuel lines should be connected for Ryobi 725r? There are three.
The line from the fuel tank that has the filter on it goes directly to the carburetor below the primer bulb. One line comes from the carburetor to the primer bulb. The other line goes from the primer bulb to the fuel tank. Primer bulb can be pressed to determine which side is pulling fuel (line from carb) and which is pushing (line to fuel tank).
May 15, 2009 | Garden
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
2,803 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
