Camera lexar is too small for my Toshiba. Is their a converter.
Is their a 2007 Toshiba Satelitte laptop converter for for my Minolta Lexar 16mb 8x.
  • RSBennett
    RSBennett May 11, 2010
    Please clarify: is the memory card from your camera not fitting in the card reader on your notebook? Or if I misunderstood, what is the exact problem?
    Thanks in advance.
Lexar sd card error, it is a 16gb Lexar sd card. When I put the card in my camera it says "card error-card is locked. Need to know how to fix this card.
SD cards have a slide switch along one edge.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 21, 2014 | Lexar Electronics - Others
Lexar 4gb sdhc memory card error
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
Jul 15, 2013 | Lexar Memory Card Sdhc 4gb Class 4
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
My computer can read the Lexar 1GB SD. But Kodak wont.
I suggest formatting the card using the utility in the camera. This will delete any data that is currently on the card.
Sep 16, 2009 | Lexar Professional High-Speed 2GB Secure...
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Mar 23, 2009 | Lexar Professional High-Speed 1GB Secure...
Lexar M S P D C:13:01 ERROR
Take out the memory stick and insert into another camera or laptop. Then you should be able to retrieve the photos.
Feb 22, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
How to unlock my 1GB lexar camera memory card
Look at your card to see if you may have broken the small tab off from the locked side. I noticed that my card looks different and I may have broken it off not knowing.
Feb 18, 2009 | Lexar Professional High-Speed 2GB Secure...
Lexar mda256-100 player from bose
The solution is correct. I emailed and received an email the next day with a firmware patch that reformatted my player.
Just an FYI, this did NOT work under Vista and since I had an XP media center laptop sitting next to me I didn't play with it. On the XP system it worked flawlessly. I ended up with a fully functional MP3 player again, nothing in the folder at all and it only took a minute.
Send them an email and I would expect you'd get a response within 1-2 business days. As mentioned, my response was within 18 hours.
Jan 06, 2008 | Lexar JumpDrive MP3 Player
Lexar Jumpdrive Secure II problem
the directory is corrupted.
when your computer accesses the drive, it knows some things, like how big it was.
but it does not know where the data is.
it does not see anything that tells it what is on the drive, thus the empty window.
not a serviceable unit if the mfg will not give you a fix it program.
sorry for the news.
Dec 20, 2007 | Lexar MEDIA - DIGITAL CAM - 64MB JUMPDRIVE...
Computers & Internet Logo
David Payne
David Payne
