Question about Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
I have a whirlpool GHW9150PW4 Duet Washer and I bought just 2 year ago. Right now once I load and run with normal cycle mode then It runs for couple of minute and than it doesn't spin. So the "Number display" blinks few seconds and washer try again. This repetaedly happen for three times and then Error shows "06" AND "F" with buzzer.
Please advise me what could be the problem
  • 360 Answers
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Posted on Mar 11, 2009
  • giorgio Jorge
    giorgio Jorge Oct 21, 2013
    I bought a Whirlpool duet washer (set). I've had problems with the washer over the last year. It is about 6 years old and out of warrenty (so the repairman tells me.) The last three weeks I have tried all the low cost solutions recommended on these websites. Since most reported that replacing electronic components, that is MCU, CCU, struts, undo the plugs and clean them, etc. I have decided to FIX the problems once and for all. I ma going to the store to BUY a new Samsung or LG top loading washer. I have had it with the Whirlpool/Kenmore products. They look nice, but they are NOT worth the troubles they cause. I remember buying a waher that would last for 20 or more years with daily use. I use mine once a week for two loads. I don't need a part-time project to keep me occupied during the weekends.
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool Duet Front loader Washer Model GHW9150PW4
there is a book inside the washer in bottom or back that gives you the trouble codes
Jun 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Lost manuel an forgot how to run cleaning mode on duet front load model#ghw9150pw4
1) turn to rinse/spin option on dial
2) select low spin speed button
3) select warm/cold temp
4) set end of cycle signal to softer
(you will notice all the lights light up in a row, that is how I remember)
5) Press the extra rince button 4 times within 5 seconds.
The bleach you add is either 1 cup if you haven't done this in a while and then 1/3 monthly
Hope that helps!
Jan 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hw do I replae the washer bellow seal on a whirlpool duet washer
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Grinding duet ghw9150pw4 front load washer
This is joyce
I just had to have my barrons replaced in my washer on the spin cycle it sounded like plane taking off. I dont know about yours but mine was loud, you probl. have the same problem. get a technician to come and check it out, all these machine's are hard to work on so let professional take care of it. if you need me to find someone in your area please just let me know.
thanks,
joyce
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin out
Is the machine draining the water out? The machine will not spin unless the water is pumped out.
Oct 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
706 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
