Question about Canon XL1S Mini DV Digital Camcorder
Canon xl1 heads
Canao xl1 have dirty heads....it shows a blue line when playing a tape. what can i use to clean the heads?
    Novelist:
  • 154 Answers
Trained technician can clean the video heads individually and manually but I do not recomend it for general public. Best you can do is to purchase a good head cleaning tape. First, dust off the tape loading area with can air, then run the head cleaning tape for 10 seconds (our general recomendation is 5 seconds) but NO MORE. hope this works. -James. For further assistance by email, go to www.camerarepairjapan.com
Posted on Mar 27, 2009
I own a Canon XL1 video camera, the problem is that Sometimes when I hit the record button the camera fails to record for up to a minute or so and then the picture breaks in. When this first happened a...
It seems your recording head is dirty, i would advise running a cleaning tape through it regularly or have the camera cleaned and checked at a Canon service.
Feb 28, 2011 | Cameras
I have a Panasonic DMR-ES35V and all is working great except it recently started showing only a blue screen when I try and play a VHS tape. Doesn't matter what kind of tape, home movie or professional it...
You can try cleaning the video heads and tape path within the VCR deck. If this doesn't fix it, then the heads are worn, or there is a fault with the head amplifier (this is part of the motherboard and nearly all surface-mounted components).
I would go with the simplest option first: check the condition of the heads, if dirty, clean them with commercially available head cleaning products such as isopropyl alcohol (IPA) head cleaning solution.
Jan 25, 2011 | Panasonic DMR-ES35VS
I have tapes with videos on them. I want to put them on the computer but I never did in about a year. I finally got around to doing it. I know there is video on the tapes but when I play them they don't...
When you get a blue screen, it is usually an indication of dirty heads. You should try and run a head cleaning tape for about 5 to 10 seconds. Then, try your tape again. If it shows signs of improvement, but still is not all better, run the head cleaner for another 5 to 10 seconds. Repeat as necessary (only running head cleaning tape for 5 to 10 second intervals). The cleaner tapes that we use in our shop are Sony brand....they last a really long time and seem to work the best.
Hope this has helped you.
www.austintelstarservices.com
Sep 28, 2010 | Canon Video Cameras
Camera will not play tapes
If you are getting a blue screen while trying to play back a tape that you know has a recording on it then its gonna be 1 of 2 things, No.1 your video heads have gotten dirty and you need to get a cleaning tape to run through the tape path to clean the unit, or No2 if your cleaning it doesnt help then you are going to need to have the video heads replaced. Usually once the heads are replaced they check the alignments for you as well and do a proper cleaning. I hope this helps
Sep 15, 2010 | Canon ZR-950 Mini DV Camcorder
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
Sep 12, 2010 | Canon Video Cameras
Hello, when I shoot lately with my canon xl1 the first few minutes of the tape only records black or you can see some of the video as horizontal bars. it is only on the first few minutes of a tape. The...
well ,,,,you got a dirty tape head,,,try running a head cleaning tape through the camcorder to clean it out,,
have you been using old tapes???
that would get the record head dirty prity quick,,,
also if the camcorder was a little damp it takes its time to warm up first,,,
i hope i have given you some idears to work on
Oct 26, 2009 | Canon XL1S Mini DV Digital Camcorder
Cannon xl1 tracking problem....record and play back all choppy...have cleaned head 4 times
How did you clean it? With a cleaning tape or how? If so, it's not good, it should be professionally cleaned. If you tried that then maybe the head has to be changed. If so, you will have to contact Canon and see how much they ask for head replacement and adjustment.
Hope this helps!
Tom
Oct 10, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Mar 04, 2009 | Canon XL1S Mini DV Digital Camcorder
Dirty heads
I work for canon and when I get one this dirty I use a tape that has been recorded with used or almost used up. I let the tape rewind and fast forward all the way through. I then use a soft head cleaning tape for 25 secs. If that doesn't work then it might need an adjustment.
Dec 18, 2008 | Canon HV20 HDV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
616 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
