Question about Maxtor Hard Drive
My hard drive power supply aint workin
When i plug the power in the LED light on the front just flashes i listen to the drive and nothin happend its like its not getting enough power to start up
can u plz help me
  • bigrogeindah Mar 11, 2009
    not sure how to find out if it does but it doesnt detect it at all anymore
  • 1,800 Answers
First off all does pc detects it as an IDE drive?
Posted on Mar 11, 2009
  • Jalal Sordo
    Jalal Sordo Mar 14, 2009
    well u need to change it to a secondary master check the jumper shematics.
    and see if it detectd in bios ITS in the IDE1 port.
Hard drive light blinks as my speakers crackle!
Loose power cable inside?
Especially if the graphics card requires one..........
Loose HDD activity LED wire, on the Front Panel header?
[Front of computer is Front Panel. Area of contact pins on motherboard, that Main wires of Front Panel go to; is the Front Panel header ]
Power Supply NOT powerful enough..
Does not have enough power for computer system, AND graphics card
http://extreme.outervision.com/psucalculatorlite.jsp
Drumroll please...................And the desktop computer manufacturer name, and model number...........is?
[Model number is on the back of the computer, or up on the side]
Regards,
joecoolvette
May 04, 2013 | Computers & Internet
Cant find my motherboard pin out
http://www.pcmag.com/article2/0,2817,2388344,00.asp?tab=Specs
With all due respect, you have the manual in front of you now
That is unless you started unplugging wires already, and didn't make notes, drawings, or take photos.
Let's use the Asus Essentio CM1630 motherboard for an example.
Couldn't find a CM1730, but that's OK. We'll use this one for a general example,
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CM1630-MOTHERBOARD-61-MIBBJ5-01-TESTED-/181007679725?pt=Motherboards&hash=item2a24e600ed
Put your mouse cursor in the middle. Now move your mouse around, using the Zoom In feature.
If this motherboard were mounted in a computer case, it would be turned 90 degrees to the Right.
Bear that in mind.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Goes by many abbreviated names.
PNL 1, FP1, PANEL1, etc.
(Panel 1, Front Panel 1, Panel 1)
Go to the Top/Right corner of the motherboard photo. To the 6 Blue SATA connectors.
Immediately to the bottom of them, is a white Front Panel header.
Two rows of contact pins sticking up.
You need to make notes, drawings, photo, whatever; of where the wires from the Front Panel, go to each one of those pins.
(Some may not be used)
How to know which wires coming from the Front Panel, are the Power On switch wires, Power On LED light wires, HarDDrive activity LED light wires?
Remove the Front Panel from the computer. If it is Not just a cover, EASE it off just enough to look behind it.
You usually can follow the Harddrive activity LED wires.
Harddrive activity LED is usually AWAY from the Power On switch, and Power On LED light.
There's two wires down.
Now look at where the Power On LED light is. Can you see wires going straight to it?
Two more wires down.
From process of elimination, you now know the last two wires going to the Front Panel, are for the Power On switch.
(The Power On switch, is part of the plastic Power On Button assembly. If you look close at the Power On Button assembly, you can see this)
THAT sir, is the MAIN thing.
I can guide you where the other cables go, as far as power cables, and Harddrive cables, and Optical Drive cables. (CD/DVD drive)
If you have already disconnected the Front Panel wires to Front Panel header on motherboard; you get to play a game(?)
Power Supply plugged into power, use a small flat tipped screwdriver, and touch two pins at a time.
When you get to the two Power On switch wire pins, the Power Supply will come on.
Now it is a process of elimination.
Use an LED with two wires, to find out what the rest of the pins are.
The rest of the contact pins in the Front Panel header.
Grab the HDD LED light, or Power On LED light.
You're getting a new computer case anyway.
Touch two pins, and the LED light blinks?
That's the HarDDrive activity LED light, pins.
LED stays on?
That's the Power On LED light, pins.
Either of those LED's are dim, (When the Harddrive is active, or when the computer is on), switch the wires around.
You have the Positive ( + ) wire mixed up with the Ground ( - ) wire.
Moving on.............
The 6 Blue SATA connectors on the motherboard:
If you look close you will see;
SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5.
Or it may be,
SATA1, SATA2, SATA3, SATA4, SATA5, and SATA6.
The Harddrive plugs into SATA0 or SATA1.
Just depends on what the SATA connector numbering starts with.
The main optical drive, or a single optical drive; plugs into SATA1, or SATA2.
A secondary SATA optical drive will plug into SATA2 or SATA3.
(Look at the SATA numbering above, and you can compare side, by side )
HOWEVER, the beauty of SATA is; that you can plug whatever you want to, in ANY SATA connector on the motherboard; and BIOS will find it.
Plug the Harddrive into SATA 3? No problem.
Plug the optical drive into SATA 0? No problem.
BIOS will find the drive with the Operating System on it.
The Harddrive.
Then BIOS will know the other drive/s are optical drives.
(Make sure in the BIOS Setup utility, that the SATA connector on the motherboard you are using, is Enabled.
Otherwise BIOS will Not see the drive)
What cable from the Harddrive, and optical drive; plugs into those SATA connectors on the motherboard?
A SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable connector.
Lines up with an L-shape on the motherboard connector.
One example of a SATA connector on the motherboard is shown.
This one is an Open design. Your SATA connectors on the motherboard, will be a Closed design.
Between a SATA data cable connector, and a SATA power cable connector, the SATA power cable connector is larger in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
See the SATA harddrive example?
Note the L-shape is pointing DOWN. It is this way EVERY time.
Now you know which way to turn the SATA data cable's connector, when installing. 'Foot' of L-shape goes Down.
More in a Comment.
Mar 14, 2013 | Computers & Internet
I am currently having the problem of not hearing the motor actuator on transfer case making any noise when i push in the 4x4 button on isuzu trooper 3.0.i am getting no 4 wheel drive and the light on dash...
On these issue,there are few solved help links for troubleshooting the issue easily.-------Click the link below:---No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
-----------4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
------------2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing? http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
----------4x4 front differential will not engage the axle on ford? http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
-------4x4 will not engage on Ford F150? http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
------------- Dodge Ram 4x4 light keeps flashing 4X4 LOW LIGHT IS FLASHING ON DASH http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
----------Ford 4x4 front wheels will not engage? http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
-------------These details will help.Thanks.
Nov 22, 2012 | Cars & Trucks
The 945GCT-M3 motherboard wireing diagram for the power sw and power led
power connecter has totally 9 pins on the board but actually we have to use only 8 pins please refer the attached image
if you have further any doubts post me
Feb 26, 2012 | E-Machines Computers & Internet
HI ON My LaCie External Hard Drive, the power LED continuously blinks and won't mount. It was working fine one minute and the next minute it was down.
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. If you have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 07, 2011 | Computers & Internet
Ive had my book for a while now and my life is on it... it was working fine and now i plug it in and nothing happends... it wont spend and the blue light wont even come on.... i check the cables and the...
#1 MAKE SURE THAT YOU HAVE ENOUGH LIGHTING .....I KNOW BECAUSE I'VE DONE THIS. I PLUGGED THE DRIVE SIDE USB INTO THE LOCK SLOT IN BACK OF DRIVE INSTEAD OF THE CORRECT SLOT......HOPE THIS HELPS..........JEFFXC
Feb 07, 2011 | Western Digital My Book Essential 1TB...
I have a Sony Vaio laptop, model PCG-384L. It will not power up. My wife indicated that she push some button that lock the power. Can seem to find the button that controls or locks the power button. ...
Typically that flashing light means low battery. Which makes sense, as you probably have an issue with the AC Adapter that you plug into the computer to charge it, or the DC Jack that this adapter plugs into on the laptop. Either of these things will cause your computer to not charge the battery, and if there isn't enough power it won't turn on.
Aug 10, 2010 | Sony VAIO Notebook
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Toshiba Laptop SPA 10 -WONT START
that just sounds like the hard drive running, try plug an external monitor and see what happends
get back to us
regards
Nov 27, 2008 | Computers & Internet
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
