Question about Lexmark X1270 All-In-One InkJet Printer
"Problem communicating with the printer" Lexmark 5270 and XPDesk
My Lexmark x5270 was working fine before I tried to share it on a network. It quit working and I've uninstalled and reinstalled the software (via the lexmark website) about 5 times now with no luck printing. The printer does seem to install fine, and is recognized by the machine running XP. However, the test page won't print and I am at a loss to know what else to do. All I get is the above message, and none of the troubleshooting offered there seems to do a bit of good. Help!
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Have you tried swapping out the USB cable?
  • Thomas F. Schneider May 11, 2010
    You have totally uninstalled and reinstalled by disconnecting the printer, Removing all software , the reinstaling it using the downloaded driver for Xp , correct? If all of that is correct they it was just an accident that it quit while hooked up to a shaired network.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
Make sure the Printer's IP Address is range with the IP Address of your network.
Note:
- Try to power cycle your Printer once after you setup the Printer settings.
Posted on Mar 11, 2009
Cannot connect lexmark 5270 to share network
If you're doing Printer Sharing, make sure that your printer is connected to the computer that is on the same Workgroup as your other computers in the network.
I hope this helps.
Nov 14, 2011 | Lexmark X5270 All-In-One InkJet Printer
Hello my lexmark printer model #5270 says Cartridge error #1203 I use black-32 color-33
The 1203 error indicates a short in one of the cartridges. Follow the steps below to fix the problem:
  1. Open the printer cover and remove both cartridges from the carrier
  2. Close the cover
  3. Unplug and re-plug the printer into the power source to reset it
  4. When the printer turns on, re-insert one cartridge first. Close the cover and check for errors
  5. Then re-insert the other cartridge. Close the cover and check for errors.
  6. Replace whichever cartridge is causing the error to appear. You can also try to insert a different known working cartridge to determine if the new one is faulty.
Jul 12, 2011 | Lexmark X5270 All-In-One InkJet Printer
Need power cord for lexmark 5270
Try to check at some retail stores or office supplies around your area. You may also contact Lexmark technical support for assistance.
Apr 11, 2011 | Lexmark X5270 All-In-One InkJet Printer
Can not get drivers for the Lexmark X5270 to work on Win7 64bit
try this:
http://www.fixya.com/support/r3680773-completely_remove_printer_drivers
Apr 01, 2010 | Lexmark X5270 All-In-One InkJet Printer
Cant get my lexmark x5270 all inone to work on new dell inspiron with vista
download and or install 'vista' driver for the printer..
try this: http://www.downloadsource.net/12455/Lexmark-X5250-X5270-Driver-Windows-Vista-32-bit/
contact ur system admin/vendor....
Oct 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Can't find Solution Center Software for the Lexmark X5270
Try a couple of steps :-
1.Make sure the wire is plugged in and printer is turned on
2.Go to control panel - printers - make sure the printer is set to default.
If the above steps are done, try the following :--
Open control panel - go to add/remove programs - uninstall everything that says Lexmark 5270
Click the link below to download the printer driver, can use help guide for the driver installation.
http://support.lexmark.com/index?page=recommendedDownloads&productCode=LEXMARK_X5270&locale=EN&segment=DOWNLOAD&userlocale=US_EN#1
Hope it helps !!
Thanks !
Sep 08, 2009 | Lexmark X5270 All-In-One InkJet Printer
Lexmark x5270
I recently had all the lexmark 5270 software erased from my hard drive and now my computer doesn't recognize my printer.Is there a cite that I can go to download the software?
Mar 09, 2009 | Lexmark X5270 All-In-One InkJet Printer
Need driver for mac os
Click the link here.
Put x5270 in the select model box.
Select your Mac OS version on next window.
TYhen click the red button that says download now.
Run the file after downloading.
Nov 08, 2008 | Lexmark X5270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
241 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
