Question about Swann Communications DVR-4-Net (SWRPCDVR4) Video Capture
Can not view my swann cameras at night. They are suppose to be inferred but they dont get enough light. What do I do?
  • 50 Answers
Well typically the cameras you have purchased should have their own LEDs installed in the front where the lens is. These smaller cameras with 12 to 38 LEDs are good for a range of only 10 to 30 feet of illumination. Anything beyond that it will not pick up. Check the specs of your cameras, make sure the cameras installed are not too high and also make sure that the distance of what you want to look at is within the cameras LEDs specs. If you do not want to change anything as far as location and height, I recommend getting a LED Illuminator. Unfortunately they usually only run on 110vac, and are somewhat expensive, and have to be mounted above the cameras to get the most of the illumination. This could be pricey because a certified technician should be the only one to install it due to codes and regulations.
Posted on Mar 11, 2009
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
Why cant I see anybody walk around my car when its dark
Is there night vision capability?
what model Swann is it?
Oct 09, 2016 | Swann Communications Home Security
I have a swann security camera with night vision & it doesn't show a picture at night. What could be the problem
Those cameras use infrared led lights to see at night. If you have no image at night then those led lights are not working.
Aug 24, 2015 | SWANN Home Security
Swann camera stays black and whie,no color
If the camera has IRs and there is not enough light it will go into black and white. Check the settings in the camera menu! If those are correct and you have good voltage it may be the camera is bad. If there is plenty of light and it is still in black and white it's a bad camera and needs to be replace
Aug 30, 2014 | Swann Communications Home Security
I have a Swann security system day/night vision cameras and the night vision has gone out on 2 of them and the system is less than a year old? Can any one help. Can these be fixed?
Check the power supply (usually 12VDC) and its connections. Lack of power for to LED's will cause the night vision feature to cease to function.
Aug 26, 2013 | Swann Communications Home Security
No colour on my swann pro-530 cctv camera
Your cameras might be in PAL mode, go into system settings and change to NTSC setting.
May 03, 2013 | SWANN PRO-530 Multi-Purpose Day/Night...
Max_ip_cam
order your router to use port forwarding!
Jun 19, 2008 | Swann Communications Opti-Viewcam Webcam
Swann Communications DVR-4-Net (SWRPCDVR4) Video Capture Logo
607 people viewed this question
Top Swann Communications Televison & Video Experts
Lawrence Oravetz
Jack Frost
Are you a Swann Communications Televison and Video Expert? Answer questions, earn points and help others
