Question about RCA L22HD31 22 in. LCD HDTV
Can i hook up a ps3 without attaching the cable? My son wants to use the tv mainly to play video games and later as a PC monitor. Do I really have to run another cable through the house just to get a signal? We've tried to hook it up with the ps3 on the VIDEO setting and just get a blue screen with the message "unusable signal".
  • 716 Answers
No you dont need cable the game consoles can hook right to the t.v. Try hitting t.v video and seeing if its on another video channel. also make sure all of the rca jacks are hooked into the in on the t.v
Posted on Mar 11, 2009
Sound aoc l22w861 lcd tv pc monitor
It may be the game options or the system options may be set to something else than speakers
Mar 20, 2014 | Sony Playstation 3 (PS3) Console
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
My playstation 3 was repaired by Sony about 7 months ago. It's been working fine. My son hooked it up to his TV today to play the new NCAA Football 11. When I hooked it back to my TV I get absolutely...
First connect the PS3 to the TV you want it on. Then try resetting the display resolutions on the PS3 by holding the power button for a few seconds when the PS3 is off until you hear 3 beeps. That should re-detect the video and should solve your problem. Hope this helps!
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
Video is fine; audio will not play. All cables
Disconnect the cable from the ps3, the one that connects the ps3 and the monitor, for a few seconds, then reconnect it. You do this while video is playing or when you play games.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
How can you hook two ps3's together without
Just hook them together via ethernet cable.
Dec 26, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Origiannly had my son's PS# hooked up to our HD TV
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • From: http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=967&p_sid=1frk_Cuj
    Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Apr 06, 2009 | Sony Playstation 3 (PS3) Console
    PS3 Works on HD TV without Sound, no sound or display on a reg TV
    when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
    Jan 18, 2009 | Sony Playstation 3 (PS3) Console
    Hello can you help with this error!
    When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
    Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
    Hope this helps.
    Sep 05, 2008 | Sony Playstation 3 (PS3) Console
    RCA L22HD31 22 in. LCD HDTV Logo
    234 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
