Question about Garden
High pressure hose connection blew up. Fix? or buy new?
Got a Black&Decker PW1600 13 amp electric power washer. The high pressure hose connection blew up. Any way to fix it without buying a new hose?
  • 716 Answers
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Posted on Mar 11, 2009
Where can I get a electric motor p/n 90520850
250 MPH Electric Blower Vac Mulcher ' BV5600 ' BLACK+ ...
www.blackanddecker.com/.../blower...blowervacuummu...
Black & DeckerThe High Performance 12 amp motor 3-in-1 blower, vacuum, and mulcher keeps ....blower I was using and I let him use it and he liked it alot said he'd never buy the ... So thanks again Black & Decker for making a safe usable product that will ...
Black and Decker BV3600 12 Amp Blower Vac - Amazon.com
www.amazon.com > ... > Leaf Blowers & Vacuums
Amazon.com, Inc. Rating: 4 - ‎138 reviews
Greenworks 24012 7 Amp Single Speed Electric 160 MPH Blower B0030BG1CC ...The Black & Decker BV3600 Blower Vac has a powerful 12 amp motor. .... really well, so that I had about 4 bags of debris to empty, and I have a big lawn.
Oct 23, 2015 | Black and Decker USA Black & Decker...
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Leaking water
You will need a new gun but if the hose is attached you will need that as well. As far as I know these small electric washers have the hoses and guns as one unit and repair is not an option.
Mar 12, 2014 | Black & Decker Garden
Black and decker electric power washer nothing coming out of wand all water coming out trigger.
Either the pressure tip or wand are blocked or the valve in the trigger is broken. Remove the high pressure tip and either try another tip or pull the trigger without a tip on the wand to see if you have the same problem. If available, try another pressure gun on the hose.
Jul 25, 2012 | Garden
I have a PW1600 Power washer. the High pressure hose connector is cracked. Can that be replaced? AND if so how do you remove it from the gun and hosing.
I don't know what brand it is, but in general the hoses can be replaced. There are fittings and hoses available. the fitting for most PW's are interchangeable. try looking at stuff here. (they do not necessarily have the best prices or stuff they just have good pictures) http://www.northerntool.com/shop/tools/category_pressure-washers+pressure-washer-accessories
Jul 05, 2011 | Black & Decker Garden
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
I have a Black & decker-pressure washer and the problem is the hose was broken. How can i fix or where i can buy a new one?
duck tape if it's completely dry and extremely tight. Mabey epoxy but that might not be strong enough. I would just get a new hose at blackanddecker . com or ebay
Black & Decker - Dewalt DP352 Pressure Washer 4000 Psi Hose
$71.99 new - TheHardwareCity.com
Jun 27, 2010 | Garden
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
When I connect the water hose to the pressure washer and turn on the water, the hose pops off.
Either the hose connection or the pump connection threads are stripped and will need to be replaced.
Aug 24, 2009 | Black & Decker Garden
Trouble with cleaning solution in my Black & Decker Power Washer
usually you have to lower the pressure at the lane for the detergent to come through as it works on a venturi principle.
can you twist or pull back on the lance to lower the pressure?
if you can take out the lance extension and run the machine you will see if that is tha cse as it should then pull deterrgent into the pump.
alternatively take the high pressure hose off the front off the machine and run it, this should also pull detergent in. if not you have an obstruction in the detergent pipe, blocked filter, regulator not open enough. or a worn injector.
Jul 19, 2009 | Garden
Garden Logo
1,130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
