Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you put on a new starter rope on a poulan# 306a chainsaw
    Novelist:
  • 152 Answers
I'm guessing the pull rope is broken.
First you'll need a C-clamp large enough to clamp the spooler, needle-nosed pliers, a small tipped screw driver and a new length of rope.
The safest way is to remove the rewind assy. cover leaving the spooler in place in its housing, try to remove the old rope with the
needle-nosed pliers and small tipped screw driver.
Next hand spin the spoiler to achieve spring tension (about 5 or 6 revolutions) and using the C-clamp to hold it in place, attempting to lineup the knot recess in the spooler with the ropes exit hole on the cover.
Then you can try to fish the new rope into the hole in the knot recess trying to guide it to the exit hole in the cover (its easier to feed the rope if you singe the end of the rope with a bic lighter and form it to a point) and with a small knot at the other end, pull the rope all the way until you can seat the knot into the knot recess.
Next tie a loop knot onto the other end of the rope, so the end wont be recoiled all the way into the housing. With tension on the rope gently remove the C-clamp and let the rope be drawled in.
If it draws all the way to the loop knot, check to see if the spooler is full if so, (not too full where its binding) pull the rope about a foot and re-clamp the spoiler and install the pull handle.
If it does not draw all the way to the loop knot and the spooler is not full, then you may need to add another revolution to the spring tension in the same fashion as described above.
There are easier ways, but that evolves removal of the spooler and repacking the recoil spring. (not a job for a novice)
Good luck
Aduz
Posted on Mar 11, 2009
Poulan chainsaw will kick back when trying to start it. It has a new cylinder and piston kit just put in it.
Sounds like the timing is too far advanced.
I'd be pulling the flywheel and retard the spark about 2 degrees.
Jan 18, 2016 | Poulan Garden
How do I change out the pull rope on Poulan 42cc chainsaw
I have found that youtube is a great place for chainsaw repair videos.
Check this one and see if it helps. http://www.youtube.com/watch?v=PsJ0sygoVBQ
Oct 20, 2014 | Poulan Garden
How do I replace starter rope on a poulan 445 pole saw?
I have pulled out the spark plug and stuffed some rope into the cylinder. The piston will then not be able to travel the full distance and will keep the clutch from turning. Use rope that will not shed particles. This will let you remove the clutch bell.
Jul 29, 2014 | Poulan Garden
My Poulan 14" chain saw has become difficult to
If you have more questions or need additional help pleasereply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa. gif,gif89a%12%00%12%00%b3%00%00%ff%ff%ff%f7%f7%ef%cc%cc%cc%bd%be%bd%99%99%99zyzrur%00%00%00%fe%01%02%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%21%f9%04%04%14%00%ff%00%2c%00%00%00%00%12%00%12%00%00%04x0%c8i%2b%1d8%eb%3d%e4%00%60%28%8a%85%17%0ag*%8c%40%19%7c%00j%08%c4%b1%92%26z%c76%fe%02%07%c2%89v%f0%7dz%c3b%c8u%14%82v5%23o%a7%13%19l%bcy-%25%7d%a6l%df%d0%f5%c7%02%85%5b%d82%90%cbt%87%d8i7%88y%a8%db%efx%8b%de%12%01%00%3b
Jan 09, 2011 | Poulan 14" Chainsaw
I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Sep 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
HOW TO TAKE THE MAGNITO OFF OF A 306A POULAN CHAINSAW
I can't find your model number at Poulanpro.com but in all the chainsaws that I have worked on the starter rope comes in the cover which is held on by usually 4 or so screws. I suggest that you go to the site I listed and look at the 42 CC engine (they have a parts manual for it) before removing anything else. Let me know if I can help further.
Mar 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
452 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
