The solution center shows a question mark on both ink cartrages, and says no comutaion with the printer.
  • 3 more comments
  • harryandgrac Mar 11, 2009
    My Lexmark X1270 will scan but will not print, Ive tried unpluging both the power cord and the put the USB in another outlet, no change
    Ive done all you suggested, I dont think you can help me and would like a refund.
    This is a printer that has been used for some time. when the the problem started I replaced the cartrages and still had the question marks.
    I've done all that. Ill take a refund.
    Novelist:
  • 149 Answers
Take the cartridges off and check the connections. Make sure that there is no dust or debris on the contacts. Also take some Alcohol on a swab and clean both areas with it. I would recommend a clean swab for each contact so you do not cross contaminate the leads. When you put the cartridges back in make sure that they seat all the way. I know that there are some cases where the cartrages look like they are seated properly but not.
Posted on Mar 11, 2009
  • 1,800 Answers
Chnage usb cable.
also try uninstall driver and install again and chnagez the usb plug
  • 13,433 Answers
Turn the printer off and then on again. see if that helps. If not try another usb port. Let me know how that goes. seems the computer is unable to talk to the printer as in it seems to be disconnected or not installed properly.
  • 10,515 Answers
  • 2 more comments
  • taran_2005
    taran_2005 Mar 11, 2009
    Did you try uninstaling the printer, rebooting, and let Windows detect the printer for you? That's the only thing I can think of. You did everything else, lastly, go to the manufacturer website and look for troubleshooting for your particular device, it could be a known issue they have dealt with....
    Thanks.
  • taran_2005
    Let me try once again......
    So, Lets start from scratch.....
    1. uninstall all drivers and reinstall
    2. Check firewall seting
    3. Disconnect and connect USB
    4. Go to control panel and check, the printer must be selected as default.
    5. Check all cables once again.
    Now, if it doesnot work, try to use the same on another pc.
    If that would work, something we have to troublshoot for printer. Unless check the usb, might be that's faulty.
    Thanks.
  • taran_2005
    Are you sure you are using right catridges recommended by lexmark?
    Thanks.
  • taran_2005
    Remove these catridges and try some other catridges that you earlier had.
    Thanks.
    Scholar:
  • 164 Answers
Hi;
Has the printer been installed correctly before? or are you trying to install a new printer?
If the system is suggesting problem with the specific cartridges are they both new?
Thanks
  • 98 Answers
Hello i hope i can help you.turn off the printer.I say that the ink cartrages are not in all the way.I have had that problem before.also mabee take a Q tip and clean any ink that might have dripped into the ink cartages inserts. that should fix that problem.
    Sergeant:
  • 320 Answers
As you will have to select the print cartridges as new after you install the cartridges.if you do not select it will show question mark. just remove the cartridges from your printer.and go to printer preferences.that you can see in properties of printer.just click the printer preferences.in printer preferences you will get a option called ---lexmark solution center.---in that there will be the option called.install ne cartridge .you click the option and follow the onscreen information and install the cartridge then.after that it will work properly.
  • 583 Answers
Unplug printer for a while then plug in then check or else reinstall printer drivers and also check connections.
    Genius:
  • 1,550 Answers
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
I installed new epson ink cartrage, but printer has red x and tells me to change ink again.? Can i just change only the bkack ink?
Yes you should be able to just change the black ink cartrage, A lot of printer wont allow other third party cartrages, is it a genuine epson ink cartridge? if so try cleaning the contacts on the cartrage.
Apr 25, 2010 | Epson NX415 All-In-One Printer
I have installed a new ink cartrage but the
Restart the computer. Turn off the printer. Turn the printer back on after the computer is fully started.
Mar 29, 2010 | Brother MFC-210C All-In-One Printer
I just refilled my ink cartrages for my Canon MP210 all in one printer and it still says low ink?
AFTER REFILLING A CARTRIDGE, THE PRINTER NEVER SHOWS THE INK LEVEL.
BUT IT WILL WOK FINE.
THE INK LEVEL WILL BE ONLY SHOWN WHEN YOU WILL PLACE A NEW CARTRIDGE.
DONT FORGET TO VOTE.
Sep 13, 2009 | Office Equipment & Supplies
How to refil Cannon LBP2900 cartridge
you do not have to take the whole printer to the shop to fill the ink cartrage if you have the manuel to the printer it should tell you how to remove the ink cartrage and replace it with a new one and also they may have a refill kit at one of your local computer stores or where they sell ink and they should be able to tell you how to get the ink cartrage out to replace it
Sep 02, 2009 | Canon LASER SHOT LBP-2900 Printer
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
Computers & Internet Logo
105 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
