Question about Toshiba Satellite P105-S6227 Notebook
I have a keyboard that has red lettering on it and I have no idea what key is causing it. I want to get rid of the ?, ? etc and get the English lettering on the keys.
  • 201 Answers
In all programs, there is font settings
youll have to go into options settings etc
to change it back to black or set to default
Posted on Jul 19, 2009
HOW Do I Get rid of numbers under the letters on the rt side of the keyboard j,k,l. etc
Try pressing the ScrLk/NumLk key that is above the F11 key.
This will turn off the Number lock.
Feb 20, 2012 | IBM ThinkPad T40 2373 Notebook
My laptop keyboard when i type in letters the letters that i hit are not the same ones that come up on the screen what would cause this laptop not even a yaer old
I guess the keyboard layout (or language settings) have changed. It is easier to help you if you tell us the operating system and which keys are changed. But I'll try to help you here.
If you have XP, open control panel and select 'Regional and Language Settings'. Following window will appear.
select 'Language' tab and click 'Details' button.
When the following window appears, check what is in the top combo box (circled in red).
If you have a US English keyboard, it should be English (United States). Otherwise select the correct one from the combo box itself.
If the correct keyboard layout is not there in the list, click the add button and add the keyboard layout you want. Then select it as the default language from the combo box.
Hope this helps you!
Good luck, and thanks for using FixYa!
Oct 29, 2011 | Compaq Presario CQ62-215DX Laptop
My dell laptop type wrong letter
The standard keyboard language and widely used setting is "ENGLISH (US)"
Set the Keyboard layout to English US so that you have standard keys for symbols etc. like @ sign with SHIFT+2 etc.
The keyboard layout / Language of your PC may have been different (other than English US), so follow these steps to select the International keyboard layout:
- Go to Control Panel - Regional and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
The above steps would change the Keyboard Layout settings to 'English US' and you would be able to type @ sign with SHIFT+2
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Aug 26, 2011 | Dell 0Y3740 Keyboard
I have a problem regarding my lg x110 notebook. some keys are not working properly like the letter g on the keyboard, when i hit the letter g it appears letter c on the monitor same as letter t and z and...
Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
Check if your number lock key is on. If so, depress the key to disengage it.
Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window. To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button. Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup. MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
Remember to clean your keyboard regularly to keep it free of dust and debris.
Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty!
May 08, 2011 | LG Computers & Internet
Shift keys don't work.Both shift works for some letters but not many. Caps lock works, but not much good for symbols on number keys
This is probably due to a mismatch between the keyboard hardware (what is written on the keys) and the keyboard settings. For example if the keyboard is standard QWERTY US English and the setting is for French, pressing some keys will give the wrong output on the screen. You can correct this in the Control Panel / Regional Settings, Language settings (depending on your operating system). For your main language, say it is English, choose the appropriate keyboard, OK/Save etc. Good luck.
Please rate Fixya Answers.
Apr 20, 2011 | Compaq Mini 110c-1001NR Notebook
Keys on keyboard not working properly
Go to control panel, regional and language settings, ensure that the correct keyboard is selected (A UK keyboard and USA English selected or a USA keyboard with UK English selected is often a cause)
Feb 24, 2010 | Compaq Presario C700T Notebook
Letter and number keys not working.
go to my computer>computer hardware>keyboard
click driver, then check if your device is working properly, if it is, click update driver.
Apr 20, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Open Questions:
See all Toshiba Satellite P105-S6227 Notebook Questions
Toshiba Satellite P105-S6227 Notebook Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
