Question about Toshiba e750 Pocket PC
SANITH,,,, thanks sanith,,but how do i open the nbo kernel file?dont know how to dont where to
I can not reset mu pocket pc toshiba e750, how can i do it.
Posted on May 02, 2009
My ds freezes when loading the R4, or it says that there is no game in the ds slot
Stuck on Loading Screen This usually indicates that the software kernel on the micro sd memory card has become corrupted. It can also happen if the micro sd memory card is overloaded with games, music and video files etc. The solution is to reinstall the kernel software on the micro sd card and ensure the micro sd memory card is not overloaded. Leave about 25% memory free.
download SDformatter and format the sd card with that, place all the files on there, none in folders..
  • Download the correct software kernel from the manufacturers website
  • Unzip the files using a suitable programme such as Win Zip or 7 Zip.
  • Open the folder containing the unzipped files and copy the 4 files (Moonmemo, Moonshl2, R4iMenu and R4.dat) to the root of the memory card.
  • At this point put the memory card into your R4 card. Start your console and ensure the R4 card is operating correctly.
  • You may have to run an upgrade file at this point
Mar 24, 2014 | Nintendo DS Lite Console
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
When the R4 card loaded up it deleted a lot of my
Honestly, first i would copy al of your ROMs to your computer, and if you want to keep you saved game, copy the .sav files also. Then after that, make sure you have the newest kernel on your computer. Then delete everything on your R4 card. correctly install your kernel on the card again (and if you dont know or remember how to do this, i have written a guide for it) and copy your roms (and .sav files!) back on to your R4 card. PS: it would be better to only copy the kernel at first, load the R4 card in you ds, then after that, load the roms and/or the .sav files.
Feb 07, 2010 | Video Game Consoles & Games
My n5 revolution got formated and i need new moonshell file, system file, and games file. can you help me
Although I personally don't use the N5 (i prefer a TT card) I should be able to help.
Try downloading and installing the N5 kernel fron this site... http://www.dsn5.com/EN-N5/download-en.htm
Make sure you download the correct kernel i.e. English N5 or N5i depending on your version of card.
Hope that helps.
Regards,
SOD69
Feb 01, 2010 | Nintendo DS Lite Console
I have just installed my first dual boot XP and Ubuntu on my old desktop. The floppy drive is recognised on XP but not on Ubuntu - What do I need to do to use it under Ubuntu 8 ?
Here are the steps to follow:
1. Click on "Applications -> Accessories -> Terminal".
2. In the terminal type "gksudo gedit" and enter the system password (you created this when installed Ubuntu). This will enable you to temporarily edit the "modules" file which is usually a read-only system file.
3. Click "Places -> Computer".
4. Click on "Filesystem".
5. Open up the directory (folder) called "Modules". It is the grey icon nearer the bottom of the list (you have to move the navigation bar down).
6. The file "Modules" should open in the "gedit" program.
7. It should look something like this:
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
fuse
lp
8. Now add the word "floppy" to the bottom of the file. It will now look like this:
fuse
lp
floppy
9. Now save the file by pressing pressing the "save" icon.
10. Exit the "gedit" program.
11. Now restart ubunutu (reboot the computer).
12. After reboot is complete, the floppy icon should be found under "Places" on the panel. Click on it to open a floppy. Remember to "unmount volume" when you remove or change the floppy. Linux will not let you change floppies like windows by just popping it out.
Hope this helps!
Oct 08, 2009 | Computers & Internet
R4 SDHC with a 2GB card
it may need different kernel software, mine runs kernel v1. 22 from this website, hope this helps, oh mine also stayed on loading screen until i learned that wen i downloaded the kernel software i only extracted the files inside the folder, u must extract the folder the files come in too, extract all and works, dont ask why? lol. good luk, www.r4new.cn/download-en.htm
Apr 08, 2009 | Video Game Consoles & Games
I got a psp and i dont know how to load games .
i think i know what your saying u might just need to get kernel add on and if u have that go to the vsh menu by pressing select and change the umd iso mode to sony NP9660 if that doesnt help then i dont know what else will unless u got the wrong kernel.
Mar 02, 2009 | Sony PlayStation Portable (PSP) Slim...
Kernel driver error message
If your able to put a motherboard out then
this will be right up your alley,,,,
After the reveiws I have read relating to this error,
have a look for yourself......
http://www.file.net/process/aslm75.sys.html
I beleieve its worth formatting the unit,
after saving the important stuff you should
formatt and start again,
30 min to load a system from a disk,
less if theres a back up image on a partioned drive,
fresh install,only way to go.....
no need to fix anything,
most important,SP2 updates give functionality
no more head aches,
WORKING,
Let the formatt begin.
enjoy,
Let me know the out come thanks
Jul 21, 2008 | ASUS A7V8X Motherboard
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Kernel panic
upgrade the os
Oct 04, 2007 | Computers & Internet
Toshiba e750 Pocket PC Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
