Question about Lexmark X125 All-In-One InkJet Printer
I can't put cartridge back in printer
Hi
i can't put put cartridge back in printer.
  • Lexmark Master
  • 19,396 Answers
Follow the setup instructions on the document below(click):
Lexmark > X125
Posted on Mar 11, 2009
  • 408 Answers
Put the bottom of it in first and then press the top toward the back of the printer.
My HP color laserjet 3600 printer continue calibrating, I can't do anything.
Try unplugging the printer. Remove the cartridges. Switch the printer back on and insert the cartridges.
If that doesn't work, remove the cartridges, unplug, put the cartridges back in and plug back in.
One of those should reset. If not, there is Support, including Chat on the HP site. Nice printer!
HP Color LaserJet 3600 Printer series
Nov 18, 2015 | HP Office Equipment & Supplies
Hi! The printer does not print colors or black. I have full new inks, an i have cleaned it many times, but it does not give any viewable text.
Hi, this is a very common problem when you leave the printer without use for many months . To fix that, you have to take your printer to a custom Technical Service and ask for a simple head cleaning. It'll be a cheap work.
_OR_
If you want to do it for yourself, get some Isoprophilic Alcohol (also, you can get Deionized Water) and follow the next steps:
1- With a syringe (one for color), remove all the ink of your cartridges.
2- Put that ink on different recipients and save it for later. 3- With a new syringe, put the isoprophilic alcohol in the cartridges. 4- Leave the cartridges all night. 5- Put the cartridges back on the printer and turn it on. 6- "Print" as many pages you can. This'll make the isoprophilic alcohol pass through the printer's head and make it "believe" is printing normally. 7- When you're done, remove the isoprophilic alcohol of the cartridges and put the ink back on the cartridges. 8- Put the cartridges back on the printer and start printing. This prints will be desaturated or blank. 9- Keep doing it until the printer is working correctly.
This is what they're gonna do at the technical service. You choose what to do.
Hope to help you.
Steelmith
Jun 20, 2011 | Office Equipment & Supplies
I have just put a new tonor cartridge in the printer but it still gives the message tonor life ended please replace cartridge
Hi
Just follow this steps.
Turnoff your printer for 2-5 mins and remove the toner cartridge, then put it back firmly. Then open your printer and try to print again. That will refresh the memory of your printer.
Jan 13, 2011 | Brother MFC-5840CN All-In-One InkJet...
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
Upon replacing a cartridge, the alignment page only appears with yellow ink and the alignment page will not print
Depending on your type of printer, this happens alot.
Take the colour cartridge out of the printer and also get a blank bit of paper, we need to bleed the cartridge.
Put on a flat surface, put paper covering surface and bang the inkspray end of the cartridge onto the paper 4 or 5 times, then you will see the colour bleeding onto the page.
Put back in printer, should work fine.
Nov 08, 2008 | Office Equipment & Supplies
Printer wont print :(
hi 59dragonfly,
did you just change your cartridge? is/are these genuine cartridges?
try to remove the cartridges. power off your printer, wait for 10mins then power it back on and also put back in the cartridges.
get back to me :)
Jul 01, 2008 | Lexmark X6150 All-In-One InkJet Printer
Compatible ink
Hi, sounds like a faulty ink cartridge, we get this now and again with selling compatible ink cartridges i suggest taking it back to the shop for a replacement wont be the printer as long as its fitted correctly with label removed..
Happy New Year
John
Dec 17, 2007 | Epson Printer
Lexmart x4580 all in one printer
Hi I have a Lexmark x4580 all in one WI FI dos not connect to my netgear it finds it and I put in all the right passwords just will not connect
Dec 04, 2007 | Lexmark X8350 All-In-One InkJet Printer
Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
May 21, 2007 | Lexmark Optra S 2450 Laser Printer
Lexmark X125 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
