Question about Kenmore 46462 Front Load Washer
I have Sears front loading washing machine. After completion of a load, there is soap residue in the form of bubbles in the rubber part I think is the ''boot''. Sears repair man said it was soap left from previous washing machine but after a year that just can't be. I use the proper detergent. Any ideas?
  • alfman541 Mar 11, 2009
    I use very little soap. About 1T and always leave door slightly open after use to dry so as not to cause odor. Thank you for your answer.
  • 3 Answers
You may have a soap buildup in the parts of the washer you can not see.Try running the machine on a short load and see if there are suds in the machine.If there is either you are using too much soap(even he)try cutting the soap to no more than 1 tablespoon.Also remember to leave the door open slightly to allow airflow
Posted on Mar 11, 2009
Hi. I have a 2nd hand WD8016C LG but dont know which compartment is pre wash, wash + fabric softener. Also, bubbles form at the window and stay at the end Thankyou
First compartment on right side of drawer is prewash, next to it on the left is wash, second compartment on right is softener. Bubbles because you are using far too much detergent. Only use 2 tablespoons max for normal fairly large wash load, even less for smaller loads. Front loaders use little water, so need much less detergent. Also, highly suggest you not use softener, leaves residue in washer that soon turns to mildew and bad odors. Use white vinegar in its place. Helps remove detergent residue from clothes, keeps tub smelling good, and is very inexpensive. Liquid detergent is also an issue--it too leaves residue behind. Powdered detergent works much better and also is cheaper(counterintuitive you would think liquid dissolves better, but it doesn't).
Dec 16, 2016 | LG Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    The fabric softner is not draining during the cycle
    Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
    Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
    Water leaking into soap dispenser when machine off
    faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
    Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
    Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
    Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
    Nov 17, 2009 | GE WSXH208A Front Load Washer
    Frigidaire ftf630as0 Front-Load Washer TUB DOESN'T WASH OR SPIN
    How old is your machine? Mine was doing the same thing. After doing some research online (and a visit from a Sears technician), I found out that the bearings died on on the drum. The Sears technician told us it was a combination of the type of soap being used (non HE), and the amount of soap being used per load that contributed to the unit's failure. I wish someone had explained that to us 7 years ago when we bought the machine. Appearently there are enzymes in the soap that will eat away at the rubber washer that protects the bearings. There are less of these enzymes in HE laundry soap, thats why it's recomended for front loading machines.I think the HE soap will still eventually cause this machine to fail, but it would take a little longer than 7 years (maybe 10 or 12). By then it's probably time to by a new machine anyways. We bought a new machine because it would cost over $500 CND to get the old one fixed. We ended up with a Frigidaire Affinity (FAFW3577KN).
    Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Suds residue left on clothes just washed
    ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
    Nov 27, 2008 | Washing Machines
    GE front loader washer soap inside door
    You can try using soap powders for 'front loading' machines......
    Mar 03, 2008 | GE WSXH208A Front Load Washer
    After cycles complete, some soap still left in machine.
    try wash it empty add no soap.. at the end of the wash cycle before it goes into spin open the lid and see if you have soap bubbles.. if you do have have a build up of soap and are using to much or the wrong soap for you area... let me know what you find out...
    Aug 27, 2007 | Frigidaire GLWS1233A Top Load Washer
    Kenmore 46462 Front Load Washer Logo
    103 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
