Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
The needle would not move up and down, it gets stuck once i start to sew,how do i get it to operate normally again?it seems to be a problem with the movement of the bobbin?
I just had this problem happen to me today. If you lift the cover off of the bobbin case, on the lower right side of the black plastic holder the bobbin goes into there is a small bump on the outside. This little bump needs to be outside of the small metal part on the right with the screw in it. What happens is that the metal part accidentally hooks onto and gets stuck on this bump. So, you may have to unscrew that part a tiny bit to loosen it, but make sure the metal hook-part is to the right of the plastic bump and you should be good to go!
Posted on Aug 31, 2009
  • 23 Answers
THis is very frustrating it happens to me to for some reason the bobbin casing moves out of the chamber and this prevents the machine to work futher, i can put the bobbin in and it will last long or not so long sometimes i am lucky and it doesnt happen for a couple of days.
Posted on Mar 31, 2009
Needle is stuck in down position and manually the wheel won't move
Try removing the bobbin case. Usually the thread is holding the needle in place, therefore the hand wheel will not operate. Once you get the thread released, it should all come free.
Sep 15, 2016 | Simplicity Sewing Machines
Needle 1/ was working ok then a noise had to power down, Now it will not let me do anything just keeps telling me to power down all the time. it is a vicious circle. any cluesTh
you may have knocked it out of time. when you heard the noise it might have been the needle hitting the fabric to hard which can sometimes knock your machine out of time. you may have to find a local sewing machine store that fixes machines. if you find one they should be able to repair it for little to no cost.
Jan 10, 2015 | Janome MB4 Four Needle Embroidery Machine
Hi, my machine does not allow feed fabric - everytime i sew it starts and gets stuck or if not the fabric does not move forward. what do i do?
Are you sewing very thick fabrics? What kind of needle and thread are you using? Have you cleaned the lint from around/under your feed dogs? Are you using spools of thread or cones? Spools should go on the spool holder on your machine and unwind from the side, but cones need a holder and should unwind from the top. Have you tried cleaning your bobbin casing?
Dec 03, 2014 | Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
The machine sews normally then once in awhile the material gets stuck in one position, does not move. The bobin thread seems to be a bit tangled in the bobbin case. What is going on?
Your bobbin may be wound uneven, try winding a fresh bobbin and make sure that you are using the same weight thread in the top and bottom. And try a fresh needle.
Oct 08, 2010 | Singer Inspiration 4205 Mechanical Sewing...
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Needle doesn't move
the problem is some fabric, dust or thread is stuck behide the plate that holds the sewing needle and foot.
Mar 10, 2009 | Kenmore 15208 Mechanical Sewing Machine
Engine occasionally jams, still able to operate manually
It's been a while since this machines been oiled. try oiling both motor hole and needle operation.
Jan 24, 2009 | Singer Inspiration 4206
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
73 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
