Question about HP Pavilion dv9000z Notebook
I have the opposite problem.after having connected with an hdmi then disconnected, i get no sound and my mute lite stays on altho i can tap it & it turns off the mute symbol on my vol control but no sound. i change back to speakers in hardware & sounds but nothing. any help much appreciated kate
  • Anonymous Mar 27, 2009
    same thing, help
How to Resolve No Sound on Windows Computer?
Ensure that you aren't muted. The Windows Sound icon is small, and it can be tough to see if you are muted or not. Click the Sound icon in the System Tray and then click the Speaker button in the pop-up that appears to toggle the mute
  • If you don't have a sound icon, then your sound drivers are likely not installed correctly.
Inspect the speaker or headphone connection to the computer. A bad connection is one of the most common causes of no sound, and is also one of the easiest to fix. Make sure that your speakers or headphones are plugged in completely, and that the cables and connectors aren't damaged.
Ensure that your speakers are connected to the right port. Make sure that your speakers are plugged into the correct port on the back of your computer. The green port is most commonly used for external speakers, while the orange and black ports are used for surround sound systems and subwoofers. The pink port is for microphones.
Make sure your speakers are powered and turned on. Many speakers require a power connection, and may need to be turned on in order to work. Check the volume controls on the speakers as well to make sure that they're turned up enough to hear.
Reconnect your HDMI cable. A common problem for HDMI users is that no sound comes out of the speakers that the HDMI cable is connected to. A simple fix for this is to unplug and then replug the HDMI cable, which should switch the default playback device to the HDMI device.
Oct 20, 2016 | Microsoft Computers & Internet
Sony no pic no sound black screen if you tap the screen it flashes lite were you tap it any help? thanks
Is the hdmi or audio video cord plugged all the way in. Also make sure you are on the right input settings. Don't tap or press on the screen
Mar 02, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hi, i have a lcd toshiba regza LV733N, and i get no audio when connected to pc on hdmi connection. but i do get audio on the same hdmi cable when is connected to my ps3. on a lcd panasonic, both the video...
You must use HDMI 1 port when conected to a PC (to have a picture). Also set the audio in to HDMI not to PC. Look at SOUND/ADVANCED AUDIO. You can use separate analog cable also... Please just read the F manual
Feb 12, 2011 | Televison & Video
Ds lite is not working. Screen is blank and no sound at all.
tap where the lighting button should be about 3 times and have you turned up the volume or are you using ear phones try the opposite to what you are currently using.
May 27, 2010 | Video Game Consoles & Games
I have an hp laptop. the sound is muted by a blue or orange icon u tap. the icon in the corner shows it is not muted but i have no sound at all. i have looked through everything and all the sound setting...
Open Device manager window and then expand Sound, Video and Game controller entry and then check whether we have two different drivers installed for audio drivers or not... If we have two different drivers like Conexant and HDMI...we need to uninstall both drivers and then we have to install the correct one to fix this issue...
1. First.. Right click on HDMI and then select Uninstall and on the next screen window, select 'Delete this device driver' option and follow on screen instructions to uninstall the driver..
Note: Please do not forget to check the option that says 'Delete this device driver
2. Follow the above steps for uninstall Conexant as well...
3. Restart Notebook..
Please reply if issue still exists...and let me know the operating system we are using in the notebook..
Mar 28, 2010 | Gateway Solo 5300 Notebook
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
Connected my x1300 to my tv via hdmi got picture but no sound. lead works and nothing is muted. plz help
Sound doesn't travel to you tv via a hdmi lead from your laptop, you would need to use laptops speakers, or a connect the laptop to a suitable audio device.
Nov 22, 2009 | Acer Computers & Internet
I cannot get the mute lite to go off
OK, there is a small flex cable underneath the keyboard that connects top panel to motherboard, needs to be replaced. You can find it on ebay.
Apr 23, 2009 | HP Pavilion dv9000z Notebook
No volume on my Samsung 50" flat screen
Go check up the settings. First disconnect all appliances and then reconnect when power off. Configure connection when power on.
See your manual. You use the analog tuner or digital cable or satelte receiver to watch TV. If external digital decoder check your settings there. They are independend and might be low or muted sound level or incorrect setting.
Apr 14, 2009 | LG 42LC2D 42 in. LCD HDTV
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
HP Pavilion dv9000z Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
