Question about Kenmore 59940 Kitchen Hood
Kenmore elite 36" downdraft dimensions
I am installing a 36" kenmore elite gas cooktop and i need the dimensions for the downdraft so when the counter top arrives the cutout will be correct.
thanks
I am using it on an island... it has a 6" high backsplash with a counter on top. How can we make the downdraft work with it?
Posted on May 26, 2010
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Downdraft ventilator has stopped working
    We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
    Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
    Need new electric cooktop to work with downdraft CV2236N-01.
    never heard of one needing downdraft usually updraft . gas maybe but not electric
    Apr 12, 2014 | Maytag MGC5430 Gas Cooktop
    Model 32353 install instructions
    Try http://www.managemylife.com/mmh/installation_guides, specifically /133509/KENMORE-ELITE-Counter-Unit-Gas-1009556L?brand_name_search=32353. As a countertop fabricator that is where I locate all the manuals for Sears appliances. All the other appliance companies make it easy to find them on their websites... Sears not so much.
    Sep 26, 2011 | Kenmore Cooktops
    My GE downdraft cooktop model JGP656 will not come up, so what could be the probelm.
    Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
    Cooktop Range Stove spark ignition does not work
    http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
    heatman101
    May 06, 2010 | GE 36 in. JGP656 Gas Cooktop
    Installing JED8230ADB Cooktop Grill with down-draft exhaust
    I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
    In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
    Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
    Kenmore Elite 30" gas cooktop installed. Large right front burner
    There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
    Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
    Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
    the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
    AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
    While he is there he can adjust the regulator to get it all working correctly
    Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
    Poor gas flow to GE cooktop
    Try a bigger inlet pipe sounds like pipe too small for load .
    Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
    Error codes 10 12 16 on kenmore induction cooktop
    We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
    Link for manual on web site appliancejunk. com is below
    http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
    Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
    Kenmore 59940 Kitchen Hood Logo
    567 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
