Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Water wont spin out
Washing machine still spins but wont spin enough to spin the water out
  • 163 Answers
Pump may have stuff in it slowing your drain down or it could be bad.
Posted on Mar 11, 2009
SOURCE: Washer spins but not enough to extract water from clothes or tub.
I have a MAH5500AWH and experienced the same problem twice. Both times the R11 resistor on the control board was burnt up. The board is behind the cycle selector dial. To check, remove the outside screws holding the metal backplate for the user control console. Do not remove the inside screws as these hold components to the backplate. My advice is to replace the whole board. You can buy a new one (expensive) or try and get a used one from a repliance repair/parts center.
Posted on Aug 18, 2006
  • 1294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
  • 90 Answers
SOURCE: Admiral Washing Machine not spinning
Make sure the safety switch that the lid operates is getting pushed down. Use a popcicle stick or non metalic object to push the switch in and try to get it to spin. This switch goes bad alot. It is in a wet environment. You will normally hear or feel a click when the switch is depressed. If not, use a putty knife or butter knife to push the top retainer in that are located at the front outer corners in the gap just where the top of the machine meets the rest of the unit. While pushing in you should feel a slight resistance but it should spring in and allow the top to lift up. Make sure to unplug the unit first.... Find the switch and unplug the two wires from it and use something like a paper clip or small wire to connect the two wires together. Let the top set back down, doesn't have to snap down and try to get it to spin again. If this works then the switch is bad... There are plastic parts on some machines that push this switch when the lid is closed that get broken off without you noticing until it just doesn't work right..
Posted on Feb 10, 2008
  • 113 Answers
SOURCE: Washing Machine doesn't spin fast enough
Most likely needs a new clutch. www.washermd.com dave
Posted on Jan 14, 2009
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
F&P GW712 washing machine, the machine washes and when it gets to the spin part it wont spin, it tries to and then a continuous beeping sound and too lights long wash & short wash comes on until...
hello what might be happening when it's going through the cycle and come to the spin part there may be not enough water empting out from the pump causeing it not to spin also there may be a fault with the module board the control the motor speed also brushes on the motor can cause spin problems hope it
regards
shaun
May 01, 2011 | Washing Machines
My indesit front loading wg1432 model washing machine wont do final spin at the end of each programe, the rest of the programe is fine, just when it comes to final spin the dial stops at this point
hello it might not be draining enough water out it has to pump water out before it spins check the pump also the filter if it has 1 hope it helps
regards
shaun
Mar 14, 2011 | Indesit W 123 Front Load Washer
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
Kemore washer
If the machine spins but not fast enough you will need to replace the clutch.
Jan 05, 2009 | Washing Machines
Dec 31, 2007 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
230 people viewed this question
Dan Webster
Dan Webster
Sal De
