Question about Rider Range Ride On
The welding on the steering of my jeep broke
Anyone know what is the Manufacturer warranty on this jeep? the welding on the right hand side of my steering wheel broke, now it cannot be steer and I only been using it for 4 weeks.
  • 10,865 Answers
Sorry to hear that. For the amount of trouble to return the jeep and try to get a warranty honored, I would look in the phone book for a local welder and have the repair done. It shouldn't cost more than $25.
Posted on Mar 11, 2009
  • Joe Hogan Mar 11, 2009
    please mark my answer as a fixya! Thanks
Magna cart became very hard to open & finally a part broke off & now one wheel no longer locks in place.Is this product fixable ? Is it in warranty ?
that depends on your purchase , did you get a warranty with it how old is it , is it out of warranty or new , tell them it was broke when you bought and just tried it ,and it fell apart if it is new , if you broke it they may not cover it anyhow , and anything can be fixed what did you brake
Mar 07, 2015 | Motorcycles
2001 jeep cherokee steering box is ripping through my frame
If the weld is done properly, it will penetrate through to the other side, All the grease, oil, contaminants must be removed before the weld is made. I mean ALL the contaminants! Then, with a drill motor and a wire brush scrub it thoroughly. blow it off with compressed air and wash it with acetone. I would do everything I could to ensure the back side is every bit as clean, Pressure washing is good. And, of course, remove the steering gear. If the holes are distorted, hammer them flat.
it will start to rust immediately. So, do this right before welding. Then, wire brush it again and paint it with rustoleum, undercoat or something of that nature, Good luck!
May 07, 2012 | 2001 Jeep Cherokee
Tank leaks can they be welded
Hi there.
Before having someone to repair tank leak, try to contact first the distributor or much better the manufacturer of the equipment and verify if the unit's tank is still covered by their warranty policy. Fryer tanks as far as I know has much longer warranty period, some manufacturer extend the warranty of their tank up to 10 years, but this is of course under normal use.
Leak on tank can be welded, just make sure that the one who will be doing the welding job is an expert and authorized on that field, otherwise, leak will not be sealed properly and accidents could occur.
Regards.
Aug 04, 2011 | Vulcan Kitchen Appliances - Others
I was mowing and all of a sudden it stopped steering. The front left wheel moves when I move the steering wheel. The front right doesn't. I can move the front right without moving the steering...
Sounds like the tie rod has came loose or broke, look for a rod that connects the working wheel to the steering and then compare it to the non working side and you will be able to see what is missing
Jun 27, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a rise and tilt recliner chair and the welding holding the side bar to the seat section has broken, where can i get a replacement part from
UP Most manufacturers warranty the frame for life. Since you did not name the manufacturer I cannot refer you to the right one. Look On-line for the manufacturer of your chair and contact them for their warranty and ordering a replacement part Hope this helps
Oct 01, 2010 | Health & Beauty
Hello, I am experiencing a "death wobble" with my 2007 Jeep wrangler 2 door. On occasion, while driving about 40 mph my jeep and steering wheel **** left and right, violently, after hitting a bump. Does...
Cgeck for play in the track bar , it goes from frame to front diff. Get a friend to move the steering wheel from left to right ( engine off ) about an 1/8 of a turn back and forth and watch for play in the steering and suspension parts. good luck.
Jul 28, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Weld on drivers side top door hinge broke door will not open without falling off how do you fix this
You will have to have it welded back on. Probably have to remove front fender to do it right.
Feb 19, 2010 | 1998 Jeep Cherokee
Were does th power steering pump go on an 1984 cj7
should be right on the top not 100% sure but should be on right hand side up top
Jul 01, 2009 | 1984 Jeep CJ7
Hand truck tires
Go to your local hardware store like ace or true value. They normally are in the parts boxes near the bolt section. Be sure to measure your axle diameter & get the right size. Rick
Apr 11, 2009 | Wesco Manufacturing Wesco Greenline Steel...
1995 Cherokee Country driver's side door weld breaks, also ALB
Weld broke twice likely because job wasn't done well. Shop didn't reenforce post when making repair. I also recommend painting over weld to cover any newly exposed metal after repaired. Don't know of any recalls...you can check nat highway traffic safety board. Sounds like your brakes would work better with abs disconnected (we all drove with no abs for how many years??) I'd do this 'till I found a good cure. On the hose thing... Pull the hose back into the cavity on both door and body. Splice with a longer piece than you need and leave the spliced ends inside the cavities, not in the "flex" area between the door & body. Good luck!
Feb 10, 2009 | 1996 Jeep Cherokee Country
Rider Range  Ride On Logo
80 people viewed this question
Top Rider Toys Experts
Thadeus Ronn Thomas
Thadeus Ronn Thomas
Level 1 Expert
Tom Chichester
Leslie Rowe
Level 1 Expert
Are you a Rider Toy Expert? Answer questions, earn points and help others
