I am looking for some opinions as to the most useful focal lengths of lenses for 4 x 5 and 8 x 10 formats. If the responders would please tell me why they feel a given length is the most useful and what they primarily use it for, i.e. landscapes, portraits, still life, etc. I would be most appreciative. I am just seriously getting started in large format, having purchased an 8 x 10 camera with lens recently. I wish to puchase some additional lenses and a 4 x 5 in the near future, but as I have no access to anyone else using large format, I hope this group can give me some insight on this matter. FWIW, I plan on doing portrait and landscape work. Thanks in advance.
: This conversion from 35mm to 4x5 does not work in practice, in my : experience. I don't shoot 8x10, but I think you'll be hard-pressed to : find someone who uses Nikkor T for portrature. And, 800mm is too long, : anyway.
I think the working distances and bellows extension discourage use of 800mm for 8x10 portraiture and would be surprised to find many people using it, but I still contend that just as 90mm lenses give a much more pleasing perspective with 35mm (than shorter focal lengths), as does a 200mm lens for 6x7cm, using 360mm for 4x5 and 728mm for 8x10 would yield that exact same preferred perspective -- the somewhat flattened compression of features that is much more attractive than even that which is had with a *normal* lens.
: Similarly, many people would consider 360 too long for : portraits in 4x5. The fact that 90mm is your favorite 35mm portrait : lens does not necessarily mean that you just mutiply 90 by 4 - you get : to crop in 4x5 without degrading the image, and you may want to give : yourself some opportunity to crop, just in case your framing is a bit : off - unlike 35mm you are not looking in the viewfinder the moment : before you shoot, and you take fewer shots.
To achieve the same desirable perspective had with a 360mm on a 4x5, using a 180mm lens instead, the camera would have to be moved back to the same working distance as the 360mm and then the image would have to be cropped to half the original format diagonal. You might as well be using a 180mm lens on your 6x7 roll-film back. But don't. Use a 200mm for 6x7!
If instead, a focal length of 180mm (or less) is used on a 4x5 at a distance that precludes cropping, the garish exageration of features becomes evident. Punchline: if you don't have a long lens or are unwilling to deal with all the problems that come with it, use a smaller format for portraiture.
: Also, there are other : considerations - I would not, for instance, want to limit myself to a : portrait lens that just barely covers the format, nor would I want to : deal with the extension necessary for Nikkor W 360 (which is an overkill : for 4x5, anyway - the lens covers 11x14 and then some). :
: Vadim
None of what I've said negates the good points you've made Vadim. I just have a strong preference for portraits done with the longer focal lengths and that can only be had by putting up with all the real-world problems you've noted.
Mike
-- /\ Michael K. Davis
MIME Attachments OK \/
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
2Pansy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
This conversion from 35mm to 4x5 does not work in practice, in my experience. I don't shoot 8x10, but I think you'll be hard-pressed to find someone who uses Nikkor T for portrature. And, 800mm is too long, anyway. Similarly, many people would consider 360 too long for portraits in 4x5. The fact that 90mm is your favorite 35mm portrait lens does not necessarily mean that you just mutiply 90 by 4 - you get to crop in 4x5 without degrading the image, and you may want to give yourself some opportunity to crop, just in case your framing is a bit off - unlike 35mm you are not looking in the viewfinder the moment before you shoot, and you take fewer shots. Also, there are other considerations - I would not, for instance, want to limit myself to a portrait lens that just barely covers the format, nor would I want to deal with the extension necessary for Nikkor W 360 (which is an overkill for 4x5, anyway - the lens covers 11x14 and then some).
Vadim
Was this helpful?
Yes
No
Solution #3
Joey2 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
: I am looking for some opinions as to the most useful focal lengths of : lenses for 4 x 5 and 8 x 10 formats. If the responders would please : tell me why they feel a given length is the most useful and what they : primarily use it for, i.e. landscapes, portraits, still life, etc. I : would be most appreciative. I am just seriously getting started in : large format, having purchased an 8 x 10 camera with lens recently. I : wish to puchase some additional lenses and a 4 x 5 in the near future, : but as I have no access to anyone else using large format, I hope this : group can give me some insight on this matter. FWIW, I plan on doing : portrait and landscape work. Thanks in advance.
: Archy E. Wiseman
If I had to be stuck with one lens for each of the four possibilites you describe I would go with these focal lengths:
4x5 8x10
Landscapes: 112 226
Portraits: 360 728
Problem is you can't get these exact lengths. They are the larger format equivalents of using 28mm and 90mm with 35mm format. These would be my choices for 35mm, so the focal lengths given above are just proportionately larger.
Here are the closest available focal lengths I know of:
4x5 8x10
Landscapes: 115 240
Portraits: 360 800
Examples:
115 -- Rodenstock Grandagon N 115 mm f/6.8 (291 mm image circle) 240 -- Rodenstock APO-Sironar-S 240 mm f/5.6 (372 mm image circle) 360 -- Nikkor W 360 mm f/6.5 (494 mm image circle) 800 -- Nikkor T 800 mm f/12 (310 mm image circle)
I have separately posted an equivalent focal lengths calculator in Excel 5.0+ format in rec.photo.equipment.misc under the subject "Equvialent Focal Lengths Calculator".
Mike Davis
Was this helpful?
Yes
No
Solution #4
man1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I shoot still life, landscape and architecture with both 4x5 and 5x7. My 4x5 lenses include a 65mm, 90mm, 150mm & 210mm. I use the 210 and 90 the most frequently. I find that due to the extreme wide angle of the 65mm, it limits its flexibility. OTOH, the 210mm enables me to shoot buildings and still life while eliminating unwanted distractions .(I rather crop in the camera if possible).
In order to get the same feel in 5x7, I use a 90mm Super Angulon, the same 210mm that I use with 4x5 (Schneider Symmar), and a 305mm.
Harold Todman Bronx, NY
Was this helpful?
Yes
No
Solution #5
Kim1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
IMO, for 4x5 I use 180mm, 90mm and 65mm. The 180 is marginally my favourite. I use it for standard still lifes and medium distance landscapes. Although many prefer 210 over 180, I find it has too narrow angle and is just a bit too long, and the 180 still gives me more than adequate coverage with all the movements I'll ever need The 90 I use for majority of my landscapes and my main passion - architecture - so I guess I actually use it more than the 180 even though I like the 180 more. The 65 I use when I want an extreme angle landscape and movements aren't necessary; mine is a bit old so it's not the most efficient of my collection but it still makes a damn fine image. Never dabbled in 8 x 10 so I can't comment on it.
Posted via Deja News, The Leader in Internet Discussion # Now offering spam-free web-based newsreading
Was this helpful?
Yes
No
Solution #6
Hart - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
EF-S 17-85mm f4-5.6 IS USM lens worked fine for >2 yrs but now autofocus has difficulty...
(More)
EF-S 17-85mm f4-5.6 IS USM lens worked fine for >2 yrs but now autofocus has difficulty locking in, especially when zoomed out. Original purchase price was close to $600. How would I go about fixing this problem? Should I send it to Canon or look for a local shop? I live in San Diego.
Hi, I just bought a vivitar 3.5x telephoto conversion lens with adapters for my nikon coolpix 5700. ...
(More)
Hi, I just bought a vivitar 3.5x telephoto conversion lens with adapters for my nikon coolpix 5700. The first photos are very distorted and out of focus at all zoom settings. Where do I start fixing? Steve
