Question about Alpine CDA-9886 Car CD/ MP3 Player
Dimmer wire connection from aftermarket delco harness to alpine
Dimmer wire on harness but not on alpine deck. I want to be able to dim the radio lights with dash lights like factory radio. where does this dimmer wire connect to on deck?
  • 716 Answers
One Of The Wires Should Be labeled Dash Lights That Comes Out Of Your Radio.
Posted on Mar 11, 2009
Should i have any spare wires when hooking up an after market car stereo
Yes, It's a very good possibility that you will have a few wires left over. Normally a wire for an aftermarket amp to be triggered on when you turn your radio on and possibly a power antenna or a dimming function that dims your radio lights when your headlights are on. It of course always depends on if you have a power antenna or not, or if you have an aftermarket amp or not or if you have the dimming feature on your car or not. These wires don't apply to everyone.
You will just match the colors between the wiring harness that came with the DUAL radio and the interface adapter that goes to your car. Make sure you use **** style crimp connectors. If not the wires could come loose or cause a popping noise or cause the radio to turn off while driving.
Other than that, installing an aftermarket radio is mostly matching the colors up between the two harnesses and crimping the wires together.3_6_2012_2_31_36_am.jpg
Mar 06, 2012 | Cars & Trucks
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Need to know how to install my deck in my 1999 chevy suburban
The best way to install an aftermarket stereo is to go to a stereo installation store and get the in dash "metra" kit and the wiring harness adapter that allows you to connect the aftermarket stereo wiring to the factory wiring on the truck...the "metra" kit adapts the aftermarket radio to fit into the space for your particualar vehicle..the tech at the stereo store will know what all this means if they know what they are doing...To clarify, "metra" is a brand name for these kits andthey also go by the name scoshe...
Jan 11, 2011 | Alpine CDE-7872 CD Player
Installed new CD deck in 07 Corolla, may have shorted something
first check the illumation fuse which to toyota its the panel fuse, check if it is blown. if not take the aftermarket wire harness u wired in with the radio harness and disconnect the orange wire (illumation wire) and see if u have lights again. sometimes the aftermarket orange wire won't work with toyota vehicles. good luck
Jun 25, 2009 | 2007 Toyota Corolla
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Illumination v. Dimmer
Good day,
The illum wire goes directly to the headlight switch and tells it when to light up, where as the dimmer wire is variable meaning it would dim up or down with your dash light control. Dimmmer is usually only need on factory radio's and not aftermarket. I suggest wiring only to the illuum lead and do not connect dim. Also about the clock make sure your red and yellow wires are not crossed, yellow is a constant hot and red is only hot when the ignition is on, so if they are backwards the radio would loose it's memory when you turn the key off.
Hope this helps
Mar 12, 2008 | Kenwood KDC-MP435U CD Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
Alpine CDA-9886 Car CD/ MP3 Player Logo
730 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
