Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
Cannot get back to vcr2 to watch TV on dish network
Was watching DVD
  • hazel77346 Mar 11, 2009
    stuck on vcr1, cannot get to vcr2 to get back to dish network, talked to at&t about help,they tried and did not work, says problem is with rca controller, guide plus - gemstar.
    was switching back from dvd to television
    after i re-connected power, on rca remove i hit vcr1 then hit who-input on rca remote and this switched tv to vcr2 and got dish network back on television. thanks
    Scholar:
  • 164 Answers
Have you looked at setting on the TV; there is sometimes a mode button to switch between different AV's. Also if the dish box and DVD box is seperate can you plug the DVD directly to the TV to check if that picks up anything or vice versa?
If your Remote has lost the coding which can happen if the batteries died or replaced then its worth re-coding the remote.
I hope this helps,
Thanks.
Posted on Mar 11, 2009
  • 583 Answers
Press and hold either the on/off, VCR1 or VCR2 button on the remote. and hold it for about 5-7 seconds. It will release the lock and work fine afterwards. The lock is some kind of childlock device.
  • RCA Master
  • 19,396 Answers
Disconnect all equipment, receiver, dvd etc. from power and remove batteries from remote.
Wait ten minutes and connect all back, this will reset all devices.
  • 10,515 Answers
What can u see when you try to back ?
  • 408 Answers
It is also possible that the codes are gone.  Try to reprogram the codes.
    Sergeant:
  • 320 Answers
Shut off the unit.and unplug all the external wires from the back of the tv and reconnect every thing after 1 minute and check out.it will work.as now its reached in stand by mode.
    President:
  • 1,314 Answers
Press the TV button, then the input button.
I have a flat screen and Dish Network for my cable. I switched the "source" to watch a dvd, and when I switched it back to channel 3 I have a blue screen. cable (dish network) is on and working....
It all depends on how your dish cable is connected to your television. The possibilities I can think of would be by composite cables (not HD)--these cables are the yellow red and white combo. It could also be component--the video cables are the blue, green and red. The other possibility is a single HDMI cable which looks like a rectangle and delivers both the video and the sound from the cable source to the T.V. as one cord. Depending on which of these you are using to output the signal from the cable box to the T.V. will determine which "source" you should select when trying to watch tv. Hope this helps!
Aug 25, 2011 | Niko Televison & Video
I want to burn a dvd from what I have recorded in my dish network. How do I set up the player so I can watch the tv through it?
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV. Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. You may need to cycle or change your input by pressing the input or source button on your TV, in order to get a picture.
Daniel Busa
DISH Network
Customer Service
Mar 26, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vollume lost on TV 2. However, the vollume works when watching a DVD.
Try to unplug the receiver for 10-15 seconds and plug it back in to reboot. Also make sure the wiring on the main receiver is connected and secured. If you are still experiencing issues after resetting the receiver we will have to send a replacement out to you.
Nick Franta
DISH Network Customer Service
Jan 26, 2011 | DISH Network ViP622 DVR DTV Receiver /...
When we watch a dvd movie our dish network symbol floats around in the background. I have contacted dish, said not their issue contact sylvania
Hello, this is Dan Busa with DISH Network Customer service, What I would check is the cable coming from the receiver to the tv make sure you only have one set. If you only have one set coming from the box, check if it goes into the DVD player. If it does, hook the receiver up separately and it should work okay.
Daniel Busa
Dec 24, 2010 | Sylvania ZV450SL8
Cannot get a clear picture with dish network I have a Clear picture when using DVD
Sometimes the input/channel for the DISH Network and the DVD are different, and if using the same for both, then you will get an unclear picture on one. If at TV1, the tv will need to be on channel 3 or 4, and possibly an input such as video 1 or 2. The DVD player may be on a different input, such as video 3, or even just on channel 3 only. If at TV2, the tv needs to on channel 60 or 73. When using the DVD, try putting the tv on channel 3 or 4, that is normally the channel that the tv needs to be on. Also, make sure that the DVD player is not on while you are trying to watch just the dish.
Becki Barned
Dec 03, 2010 | Apex Digital LD4088 LCD TV
How to hook up dvd to tv through dish network box
I do hope that you have gotten this resolved, but if not, here are some steps.
From the receiver box:
You will want to connect RCA (red/white/yellow) from the TV1 slot to the IN on the back of the DVD. You can also use coax, which would then be connected to TV SET OUT on the back of the receiver.
From the DVD:
You will want to have more RCAs going from OUT on the DVD to the TV. Then the TV needs to be on channel 3 or 4, and on an input. Usually Video 1 or 2. The DVD will need to be on whenever you are watching the DISH.
Becki Barned
Jun 26, 2010 | Vizio L32 32 in. LCD HDTV
I have a Vizio P42HDTV10A with a Bose 321 system and no sound
Check you cables. make sure that the Dish Box is hooked up and if you are run'n your cables from the Dish Box to the DVD player then you will have to keep the player on.
Use to work for DirecTV i got this all the time
Aug 25, 2009 | Vizio GV42L 42 in. LCD Television
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
May 30, 2009 | Coby DVD-958 Theater System
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
