Question about Calculated Industries ConcreteCalc Pro 4225 Calculator
Salt got on small piece of my concrete and now it is breaking down. i am getting all these pitted holes about the size of a baseball. it actually looks like the concrete is peeling.
  • 10,865 Answers
Salt is evil when it omes to unsealed concrete. Hose down the area and remove any remaining salt. Then go to a cement block/brick yard and speak with the clerk about your problem. There are several very excellent concrete patches that will do the repair. Finally, I would seal or reseal the entire concrete pad.
please mark my answer as a fixya!
Posted on Mar 11, 2009
What is the difference between baseball and softball catcher's mitts?
The main difference between baseball and softball catcher's mitts is that the softball mitts have slightly less padding. This allows the softball catcher to grasp the ball easier, because it is much bigger than a baseball.
Feb 06, 2013 | Baseball & Softball
Waterside water softener model MC250 Dear Sir, Salt level did not go down during regeneration. I poured 2 pints of warm water to break solidified tablet salt, I found moist salt, but very little water in...
the salt in use should water softener salt and nothing else
there is water added to the salt crystals up to the overflow hole
during regeneration that salty water (Brime) is drawn into the unit and upon finishing the process that reserve is refilled for the next time
there is little salt actually used during the regeneration process ( around 4 regenerations to a 25 kg bad )
Apr 13, 2017 | Dishwashers
What to do if water pump bolt breaks,97 mercury mountaineer
You have to drill the remainder of the bolt out of the hole. Start by taking a center punch and punch the dead center of the piece stuck in the hole, then take a small drill bit and get to work on the punch hole. Use a little wd40 on the bit to keep it from overheating and go about half speed on the drill (time consuming prosses). After you drilled deep enough grab the next size bit and continue to do this until you can fit a good size extracter in the hole to pull it out. If you do not have an extracter then continue to drill untill the bolt is completly out then retap new treads and find an oversized bolt.
Sep 14, 2011 | 1997 Mercury Mountaineer
The front door handle lacks tension and the door won't open from the outside. However, the door will open from the inside.
I just bought a 96 transport with that same problem on both front doors they would open from the inside but not the outside. They have a design flaw, basically when you pull the handle it pushes a piece that pivots and in turn pushes a linkage rod downward that actuates the door latch, well that pivot point is the weak spot, the pin that it hinges on is too small and will break, (I found the pivot piece and the linkage rod laying in the bottom of the door)
If you pull the door panel off their are 2 nuts holding the door handle on, take those off and the door handle will come off, the pivot pin is on then inside of the door handle, what I did was to drill a hole and put a small self tapping screw in to replace the pivot pin, and hold the pivot piece and linkage in place then put it all back through the door handle hole in the door, and set the linkage down in it's hole in the door latch assembly. The screw I used was not exactly the same size as the original pin was so the pivot piece had some play in it and did not quite push the down far enough to unlatch the door so I put two small nuts to act as washers on the bottom of the linkage rod so it would push down a little more, now it works like a charm, on the other door the linkage rod had just come out of it's hole in the door latch assembly, all I had to do was pull the inside door handle, which lowered the door latch piece and guided the rod back into its hole as I released the inside door handle and now it works too, took about an hour for both doors, a fairly easy fix, hope this helps.
Dec 15, 2010 | 1996 Pontiac Trans Sport
While washing heavy load (towels) spin cycle became very loud and sounded out of balance. After cycle finished, noticed several small pieces of white material. Washed a light-weight load next; same loud...
I had exactly the same problem, sound and everything. I just pulled the front off the washer and discovered that I half mooned shaped, big hunk of concrete was broken in half and hanging down rubbing who knows what. I'm sure it's just a weight to help make it stable while spinning. I don't know if the broken concrete is a result of another problem or not. I'm going to try to find a replacement and install it myself and see if it's fixed. I can just hope.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our V&B Toilet is leaking water from the base of the unit (i.e. where it is concreted to the floor). The plumber who came to look at it seems to think that he has to break the toilet to get into it to...
yes it is a wax seal under the toilet, There is just 2 screws holding it down to the floor. Anybody could take it up and fix it.
The bolts are on the two sides down on the base. Prob has small square covers over them
Jun 02, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
Cant stop rust on rocker panels
If someone could solve this problem forever they would become instant millionaires!!! (it is an ongoing problem with just about every vehicle forever (road salt and pitting from stuff that gets kicked up by tires, does not care what kind of vehicle it is) I generally use a product called rust killer. Just follow instructions on container. I have a Jeep (noted for rust there) I use rust killer, then cover the entire rocker with fiberglass, then spray the entire thing with bedliner coating. (if you need to match paint on car, just re-spray over it with correct colour)
The biggest problem is that the rust you see is not all the rust that's there...it actually begins inside the panel where you can't get to ...that's why it bleeds rust stain through the paint before holes appear.
Good luck! Hope this helps you.
Apr 23, 2009 | 2001 Pontiac Grand Prix
Trying to find hole below evaporator in freezer
The aluminum is the collection tray that the water drains down and goes down the tube to pan under fridge.
With all the ice you are talking about it will be hard to see. You might need to get a towel and mop up excess water as you go.
Get a shop vac if you have one and put the hose in the end that blows instead of vacuum's the warm air will aid in defrosting the ice out of coils. Other wise use a hair dryer. The drain is in center right below the coils. When you get to where you are closer to the as you say aluminum you will notice a small diameter hole say just smaller then a penny in size. Now get some table salt and put approx. 2 tea spoons on the top of hole. this will melt the ice much faster and clear out the drain tube in minutes. Then just clear out with some water and you can monitor the pan under the fridge to see how much water comes out. Hope this helps ken
Jan 18, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Calculated Industries ConcreteCalc Pro 4225 Calculator Logo
258 people viewed this question
Top Calculated Industries Office Equipment & Supplies Experts
Vernon Taylor
Joe Garcia
Joe Garcia
voyager663rd
Are you a Calculated Industries Office Equipment and Supply Expert? Answer questions, earn points and help others
