Question about Dell Dimension 8400 PC Desktop
Can't install WINDOWS.
I just bought a brand new WD Sata Hard drive for my Dell Dimension 8400. I tried installing Windows XP Pro, then I attempted to install Windows XP Home. I got my new hard drive formatted but I can't get either operating system to install. Is there something I'm missing. I have boot CD's for both OS's but I am stuck right now. I can't do most of the options when I'm given them.
  • 35 Answers
WindowsXP does not natively support SATA drives. The install disc doesn't contain any SATA drivers for these devices. You can retrieve the correct driver HERE, and slipstream the driver into your windows disc. For slipstreaming tutorials and software, go HERE.
Posted on Mar 11, 2009
  • 135 Answers
Install the XP Pro first, install the necessary drivers etc. Then after that load the other disk for windows XP Home install it choose the drive to install the OS, install the necessary drivers etc. you will see two operating system while going to boot section of the computer.
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
I have a Dell Dimension 8400. The hard drive crashed so I went to the Dell website, entered my System Service Tag #, bought the reccomended "compatible" hard drive which is WD 1600AAJS 160 GB...
It will be easier if you will have it checked with any computer technician. They will normally charge a very minimal fee for this very common kind of problem.
Be sure to be there when he checked your computer, so he can also teach you about it.
Mar 02, 2017 | Western Digital Caviar SE WD1600AAJS 160...
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
I have a dimension 8400, I recently upgraded my graphics card. Followed the instructions, blew out the computer of dust bunnies, inserted the new card, tured on the power, machine went from start screen to...
check the power cable and ide/sata cable connecting the hard drive to the motherboard maybe they are just disconnected, if the unit is working properly before you cleaned it, or does the unit detect the hard drive and cd/dvd drive during power on self test, if yes then you do need to re install windows, if you do not have an xp cd then you just have to purchased a genuine copy if you want to troubleshoot it by your self, or just take to it to comp. tech save trouble and lost of your time
Nov 24, 2009 | Dell Dimension 8400 PC Desktop
I have a Dell Dimension 8400 that I just installed a new sata hard drive on. I've tried many times but I can't get 'windows XP' installed. It's a brand new hard drive and I formatted it when I tried to...
Is i giving any errors when you try to install? You may need to download the Sata controller Drivers from Dell and when prompted choose the F6 option and install them then.
Hope this helps,
David
Mar 11, 2009 | Dell Dimension 8400 PC Desktop
When installing a new hard drive the system bios recognize the drive. However, when I start to install Windows XP, the program does not see the drive as being present. How can I get the computer started...
What type of hard drive is it. Sound like you put in a SATA hard drive. You need to load the drivers for that hard drive. During the Windows XP setup it gives you an option to load 3rd party drivers that what is sounds like you need to to.
Mar 05, 2009 | Dell Dimension 8400 PC Desktop
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 8400 cannot see SATA drive when trying to do clean install on new drive or on old drive. Thought the old drive went belly up but new drive does same results. Setup of drive using western...
It is not a controller problem. When you install XP with a SATA drive, You get to a point on the install where you are asked if you have 3rd party divers to install. You have to hit F6 and point it to where the SATA drivers are. You need the SATA divers for you unit. Dell may have them on their website.
Without the SATA drivers, Xp will not see the serial drive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 23, 2008 | Computers & Internet
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Dell Dimension 8400 PC Desktop Logo
273 people viewed this question
Alun Cox
