FixYa.com
Tags:
Vanguard Vanguard 10 x 25mm Compact Binoculars
Guitar repair question - nut shim
By 2Pansy - usenet poster
Hello all,
I need to add about a .25mm shim below the nuts to my Kramer
Vanguard guitar (my 6th string bottom outs on the 2nd fret). My
guitar teacher mentioned Lexan but I have no clue where to get
some. Any advise?
Thanks in advance!
Scall5
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
Helpful (85)
Luisa_K
Luisa_K - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Scall,
Shimming a nut will raise all of your string equally by the
amount of the shim. It will also have an impact on your tone...perhaps
not perceptible to you, but it is there...here's why. The string of a
guitar is designed to vibrate between two fulcrum that are properly
coupled at two points. The first is on the body at the saddle (bridge),
the second is at the end of the neck either as a zero fret or as a nut.
Any material placed in-between the nut or saddle will slightly uncouple
the fulcrum which means that part of your string vibration will be
transferred to the space between the shim and the guitar and betwen the
shim and the fulcrum (like the ham in a burger ;-) This uncoupling
(however slight) means that your sustain will suffer (and thus your
tone will change). The better solution is always: Go to a luthier/tech
and have a new nut properly cut...and here's a good chance to
experiment with new nut materials (like bone or Tusq). If you need to
use a shim, my preference by far would be to use a hardwood veneer,
preferably one that is similar to the wood in your neck (likely mahog).
I would also fix the shim with a little bit of Hide glue to maximize
transfer (rather than leave it floating). I would then fix the nut to
the shim with a drop or two of Cyano.
It is evident that your teacher thinks your nut action is too
low...here how to measure it properly. Place a capo (or finger) on the
THIRD fret. Now measure the gap between the bottom of each string and
the top of the FIRST fret. There should be a very, very slight gap
(about the thickness of a hair...a little more on the bass side than
the treble). If the string is actually resting on the first fret, the
slot may need to be raised...if all the strings are resting on the
first fret, then the nut needs to be raised. In your case, if only one
string is causing the problem, raising the slot is likely a better
solution (though not as good as a new nut). It is rather important
before you do anything to be certain that this is the problem...if you
raise the nut slot and the problem is actually a sprung fret on the
second (look at the second fret on the bass side...now press down on
the top...does the fret move up and down (even slightly)...if so, your
nut is fine and you need to tack down the fret (by seeping in a little
viscuous cyano acrylic glue).
The nut needs to be cut rather precisely with things like back angle,
width, and the shape of the seat all being customized to the string and
headstock angle and the radius of the fingerboard. This is why there
are specially made nut slotting files that only cut on the edge and
that come in precise thicknesses to match the string gauge. You can cut
it with other implements of destructions, but your success rate will be
hit and miss with these McGyvered solutions unless you have a lot of
experience. For this reason, I would not fill it as mentioned in other
posts...you'd want to smooth the seat and properly shape it after
filling, and without the proper files, this can be your downfall.
Rather than go this route, I would suggest that you simply buy a roll
of plumbing tape (a.k.a Teflon tape). This is the white tape that is
designed to go around the thread of water pipes ensure leak free seals.
If you fold a small hunk over a few times, you can fit it in the slot
and tune up. The pressure of the string will shape the seat and
compress the material...the teflon is very slippery and will discourage
binding (the symptoms of a badly cut nut slot). This is 100%
non-destructive and about as effective in slightly raising a slot that
was cut too deep...you simply need to loosen the offending string,
place the tape in the slot and replace the string...it is ready for
tuning and testing...add more tape to taste. Yes, this also uncouples
the string slightly, but not near as much as a shim.
If you do insist on shimming your nut (which is acceptable, but not
optimal), you need to be a little careful. Most makers install the nut
before they finish, and so, here are a few cautions when messing with
the nut. First: Remove all the strings. Next, score the headstock side
of the nut with a sharp knife along the seam of the nut to break any
bond with the finish...otherwise, you will likely take a big hunk of
finish with your nut. To remove the nut, place a small wooden block on
the fingerboard, and lay it against the nut. Using the palm of your
hand, give the block a slight rap towards the machine heads...watch
out, the nut sometimes flies off. DO NOT sand or file the seat without
the proper nut seating files...you will likely need to do some cleaning
(most nuts are held with a small dab of glue and this will need to be
carefully removed before proceeding...go slow). You really want to
avoid taking anything off the exposed end of the fret board...bringing
you nut closer to the bridge will invariably mess up your intonation as
you alter the scale length.
There is little doubt that the Low E (the fat wound one) is
problematic. The fatter the string, the more space it need to vibrate,
so it is essential that the bass side have slightly higher action than
the treble. It is also essential the the relief is not too excessive
(causing a big dip in the middle of the neck (~7th fret) and shallow
sections from the 1st to 3rd and 12th to 14th frets). However, you
should also be aware that the Low E will buzz regardless of your string
height if you 1) have a very strong downwards attack (causing it to
vibrate really hard when compared to the other strings), 2) Have an old
tired string (true of all wound strings...as the winding deteriorates,
the string will buzz) or 3) have sloppy fretting technique.
Diagnostics on stringed instruments are not always evident and a
solution sometimes appear complete unrelated to the symptoms. All do
respect to your teacher, my advice would be spend the $45 to bring it
in for a proper setup...mention your buzzing and stick around...your
axe should play better.
Cheers, CS
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
Not exactly. ECA hardens due to contact with moisture condensation.
Baking soda draws moisture to it in a way the other materials you list
don't. The soda is also shaped in a way that allows more density. Sure
the other materials will act as filler and the ECA will cure, but the
best is baking soda. And, you want to recommend the best, right?
Solution #3
posted on Jul 14, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
theres probably 20 ways to stop the buzzing. and maybe something isnt 'perfect' but its probably close enough. and sure you can throw money at the problem. but all you really need to do is to stop it from bottoming out. having slightly high action isnt the end of the world.
just stick some teflon tape under the string like the first guy said. cost you all of a dollar and will very probably fix your problem far better and eaisier than any of the glue it and refile it solutions. ive used it for years on several different guitars and saved loads of cash.
with all due respect to your teacher (who is not a luthier, nor am i for that matter...) imho, the shim solution is just dumb. once you bother to remove the old nut, just get a new nut made.
Solution #4
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
Lumpy:
[repairing a deep nut slot]
Dave Van:
Bicarb, Cornstarch, Bone dust, fingernail grindings,
micarta dust (formica), plastic grindings from a
ball point pen casing, diatomaceous earth, chalk, borax.
Almost anything will work. The heavier the 'dust' is,
the easier it is to work with.
But it's just about as simple to carve a new nut.
Lumpy
How come you didn't star on Star Trek?
Because Clint Howard beat me for the part of Balok.
Solution #5
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
in article , Lumpy at
wrote on 6/18/06 12:47 AM:
Make sure it's the thin running ECA... and it's Baking Soda, not cornstarch.
Solution #6
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
I'm sensing the need for a second opinion.
How is the rest of the setup?
12th fret action?
12th fret action while 1st fret is fretted?
1st fret action while 3rd fret is fretted?
That's where nut height is typically measured.
7th fret action while 1st and 17th fret is fretted?
Why do you think the amount you need to raise the nut is 0.25mm?
What will happen to the other strings when you raise them?
You use the term "nuts" as in plural. Are you sure you're
talking about the nut on the guitar, the piece between
the 1st fret and the tuner machines?
And the most confusing part of your teacher's advice,
why Lexan? I can't imagine that lexan comes in a
material that thin.
The right way to do it, if you really DO need to
do it, is to simply make (or have made) a new nut.
The quick fix way to do it, again if you really DO
need to do it, is to fill the offending nut slot
with super glue+cornstarch and re-file the slot.
Lumpy
Can you do that FM disc jockey voice?
Yes, but it doesn't translate well in ascii.
Can you Help with these Binoculars problems?
Binoculars
software for my vivitar digital...
I am looking for the softwware... Answer This...
Binoculars
PV series 2 x 22 Vivtar...
replacement of rubber ring on... Answer This...
Binoculars
Child's night light
Dear Sirs, I bought a couple of... Answer This...
Binoculars
Helicopter spinning
Helicopter keeps spinning... Answer This...
Binoculars
sky scrambler
Do you know where i can find... Answer This...
Repair Service
Find Binoculars Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
