Rinse water doesn't stop filling on large load setting
If I watch the water fill to the level I need then put the setting on medium level the machine continues to work. If I allow the rinse water to fill on large load the machine overflows. Any ideas?
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
Hi, my machine is not starting its cycle, it is filling with water and then stopping, there are no warning lights, it just flashes on the rinse mode. I have unscrewed the valve on the front right of the...
I don't think the problem is your filters. If you had clogged filters it wouldn't be filling with water, or if you had a bad water valve (not electronically opening the water valve) again it wouldn't be filling with water. I have to go through this in my own head so bear with me. :0).
The fact that the water is stopping seems like the sensor for it being filled to the desired level is OK, but having said that, have you tried setting the water level to a Small, or Medium load just to confirm the water sensor is fully functional? Now you say it had "excess water"...is it overfilling? if it's overfilling then maybe your water level sensor is malfunctioning? if you confirm the water level sensor is working at Small, Medium, Large settings where it's not overfilling, then I would look at the main cycle switch as maybe being bad. If the water levels are incorrect and it seems that may be stopping the machine from going to the next stage in the cycle, I would closer at the valves. See if you can find anything online for your particular washing machine. There are sites out there for just about anything.
Dec 21, 2017 | Miele W865 Front Load Washer
The level of water in the rinse cycle is extremely low to the point that the clothes are not rinsed. Why is there such a large differential between the level of water in the wash and rinse cycle? How can...
Low water pressure or bad inlet valve, or clogged screens in fill hoses, check flow with hoses disconected these will be the causes! check hot and cold fills than check warm, any differnt all setting work?
Aug 23, 2011 | Estate ETW4400VQ Top Load Washer
I put a fairly large load in washer. As the washing started I needed to add an item. I was surprised that the machine had very little water in it. Is there a way to add more water. Also when soaking I had...
The Series 10 and 11 machines have three level fill points the Series 12 and above have two level fill points.
I know Bulky Items wash selection will give you a High water fill which is only 7 inches or so of water in the wash basket. 3.5 inches of water for a medium fill.
You can turn on/open the water inlet valves in Service Mode but I would not recommend that. A manual fill as you did is the only safe way to set the additional water level IMOP.
FAV6800A/FAV9800A Service Manual for reference.
Rich
Jul 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
