Question about Olympus Camedia E-10 Digital Camera
The compact flash slot in my Olympus E10 has two bent pins
Can I switch to smart media and not worry about the compact flash or will I continue getting errors? Can this be replaced and or fixed?
  • josephzubik Mar 11, 2009
    So even if the compact flash slot has some broken pins I can switch to the smart media option and the camera would operate off of the smart media slot?
  • 919 Answers
You can also use the smart media card slot. The two cards function independently of each other.
Based on what you report the camera would need to be serviced. Regretfully all parts, accessories and repair service have been discontinued due to the age of the camera.
You may refer to the yellow pages for local camera repair centers who maybe able to offer parts and service on the camera.
As a loyal Olympus customer, our Customer Service Department is also available to discuss other options available to you.
They can be reached Monday through Friday, 8:30 AM until 7:00PM East Coast time, at: 1(800)622-6372 option 2 and then option 3.
Posted on Mar 11, 2009
  • BabsOne Mar 11, 2009
    That is correct. The camera should default and detect that a smartmedia card is now inserted to the camera and write the images to that card. As I stated earlier, the cards are independent of each other.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Memory cards are locked but the card is not locked
It's unusual that an A95 would report "card locked" as it uses a compact flash card which is incapable of being locked. Please verify the model of your camera, and the card that it uses.
In the mean time, I'll assume that actually own a different camera that uses SD cards. If so, please see this link for troubleshooting tips for SD card locked problems.
But if you indeed own an A95 with compact flash, the problem may possibly be caused by bent flash card pins inside the camera card slot (take a look inside using a flashlight). If bent pins are found, then see this link for a possible home fix.
Apr 15, 2010 | Canon PowerShot A95 Digital Camera
Bent pin in card slot , i have bent one of the pins that fit the compact flash card is there any one out there with spares to repair, ta steve
This is not a consumer repairable problem. Take it to a professional. If it's just a bent pin (not broken), the repair shouldn't be too expensive.
Oct 09, 2009 | Cameras
Olympus e520 will not turn on
try to rest your camera and see if that works
Apr 20, 2009 | Olympus E-520 Digital Camera with 14-42mm...
Olympus E10 pins bent on compact flash slot
Mar 11, 2009 | Olympus Camedia E-10 Digital Camera
Olympus E500 card error
check the pins in the cf slot.. should be two even rows and straight... probably needs repair
Dec 13, 2008 | Olympus EVOLT E-500 Digital Camera
HP PSC 1610 All-In-One - Memory card Error
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Sep 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
E100 Memory
I just bought a 1GB compact flash card and I was really amazed how fast they are. Lexar has them with 80x speed.
Sep 11, 2005 | Olympus Camedia E-100RS Digital Camera
How long do the normal batteries last?
I use a 2500L for studio portraits and the E10 is on order. Invest in the remote release (the E10 is a huge improvement over the 2500L on that score), the ac adaptor - no need for extra batteries at all and if you wire the computer to the camera you will only need one (fairly large) memory card. The last facility I just mentioned will be an absolute boon in the studio - not so outside. I have an iBook with USB and the way I have had it explained to me is that the camera memory card physically mounts on the desktop of the computer just like another storage device. The thing I hate about compact flash cards is the adaptor that I need to use to download to my iMac and iBook makes things very fiddly but CF cards are much more robust than Smat Media. In a studio with the E10 you would never need to remove the card from the camera! The benefits are huge. Take a shot (or shots) copy them straight onto your hard disk, open them, manipulate them and print them. And take the money! One other thing. I always shoot at the highest resolution with no compression - ie TIFF files. On the E10 they are 12 megabytes each I guarantee that the moment you choose to shoot images at the lower
Sep 07, 2005 | Olympus Camedia E-10 Digital Camera
Olympus Camedia E-10 Digital Camera Logo
182 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
