Question about Kitchen Ranges
Hello There
Welcome to the world of Viking. This is a reasonably straight forward fix if you've gone through he headache before. Right, here is a step by step explanation which will get it resolved.
The problem is with one or more of your glow plugs. your oven has 2 one for esch side, one of your glow plugs in the oven is not working hence the limited heat.
There are 3 glow plugs (one for each of 2 oven burners and one for the broiler).
2. Once the glow plugs are glowing strong they pass 3.2 to 3.6 amps of current to the "dual bake gas valve" or "single broil gas valve" (there are 2 gas valves [one dual for oven, one single for broiler]). The gas valves are bimetal types which release gas once the glow plugs are glowing.
3. The gas valves release gas for ignition and the glow plugs turn off.
I would suggest that your glow plug needs replacing (unless for some reason a wire is broken), Check for continuity, etc.
I would strongly suggest changing all 3, becuase if one is faulty you can bet your botton dollar not long time down the line the others will too.
You can get your Viking ignitors from Carl Schaedel (a Viking distributor) for around $40 each. Compared to the suggested Maytag replacement from http://www.repairclinic.com/referral.asp?R=1265&P=69 which cost ~$65 each.
Purchase from www.carlschaedel.com phone # 973-244-1415 (1-800-750-9857).
Good luck and hope this helps.
PCGuy30
Posted on Mar 11, 2009
Gas Range
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
The burners of a range/oven are the heating units that you cook things on. We call the top area where the burners are the "range." Some people call it the "cooktop," others simply say the "top of the stove."
In a gas oven, the broiler is located either inside the oven, or beneath the oven in a drawer. If the broiler is inside the oven, the top metal rack of the oven serves as the broiler rack or shelf.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box-before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It won't bake
It bakes poorly or the temperature is wrong
It won't broil
A burner doesn't work
It won't bake or broil
The clock doesn't work
There's an error code on the digital display
The oven light doesn't work
There's a self-cleaning problem
The door won't close
An indicator light doesn't work
The oven is hot on the outside
I smell gas!
Learn more about your range, stove, or oven
Oven replacement parts
If the over is not getting as hot as it should be, it sounds to me like you have a thermostat or heat regulator problem.
Apr 15, 2014 | Viking Kitchen Ranges
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jan 15, 2009 | Viking VGIC305-4B Gas Kitchen Range
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Aug 06, 2008 | Viking VGSC306-4B Gas Kitchen Range
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
154 people viewed this question
