Question about Archos 605 WiFi Digital Media Player
Ghost librarary: deleted files still shown on media directory
While in PC Hard drive mode I deleted everything (intentionally) from my music library. So my "Music" library on the device should be empty, but when I go to it all the files are shown as still existing. When I try to play or delete them, though, it says I can't do either because the file cannot be accessed.
But when I go to the music folder by first going to "Files" there is nothing there. How do I erase the lingering files that cannot be accessed because they do not exits???
The problem is that the Archos stores library information separately from the actual files on the device and the library must be updated whenever the files are changed.
To manually update your library:  From the main screen on your Archos 605, choose the Settings menu from the bottom right corner and select "System".
If there is an "Update ARCLibrary" button available, then click that button and see if it updates your device.
If the button is not there, or does not work, then try temporarily switching the "UBS Preference" setting to 'Windows Media Device" and closing the Settings screen.  This should invoke the library update.  Once updated, you can switch back to PC Hard Drive Mode.
Posted on Mar 24, 2009
I want to remove existing music
You cannot delete existing mp3 files/directories directly from the player but it is possible from the computer. Connect your mp3 player to a PC using the USB cable. It should become visible as a mounted removable drive.
If you can't see it, go to settings -> system and switch the UMS mode at the bottom of the list so it can become visible.
You should be able to see the drive in windows explorer and on Windows, you may even be asked as the drive connects if you want to view files,
Simply go to the directory structure, click through to music and delete files/folders that you no longer want. You can copy over new files from wherever you store your music, too. It's the same connection/viewing process.
Jan 01, 2014 | Samsung YP-Z5 MP3 Player
Tip
Moving the iTunes Music Files to a Different Hard Disk/Folder If you are low on...
If you are low on disk space in your iTunes folder then you can move these music files to another hard drive and keep your music library in tact without the need to create your music library again.
If you want to transfer your iTunes to an external USB hard drive, make sure that it is powered up and connected to your computer before opening iTunes.
Opened iTunes, click Edit and then Preferences. Click the Advanced tab.
Make sure the Keep iTunes Media folder organized checkbox is checked, and click Change.
Then select the location where you would like to move your files to. Click Select the Hard Drive and Folder or OK once you’re done.
The files will not move into their new positions by themselves –To do this – click File, Library and Organize Library. Check Consolidate Files.
When this process has been completed, go to the new location of your iTunes media and check the music files to see if they have migrated across correctly. Also play one or more tunes to test the music files.
The redundant iTunes music files can now be deleted from the original iTune location (C:\Documents and Settings\…..…\My Documents\My Music\iTunes). Delete everything from iTunes there except files titled iTunes Library.itl and iTunes Music Library.xml. These are still needed.
on Jun 05, 2010 | Computers & Internet
I DO NOT KNOW HOW TO REINSTALL THE M.S.OFFICE FROM GHOST FILE IN HARD DISC.
If you are using "Norton Ghost" then it is similar to a standard backup/restore programme.
Open Ghost, select all of the files you require, if it is a programme that you want then you must include the Windows directory and System 32 directory as there are files the computer requires to register the programme again.
Usually Ghost is used to replace all of your data on the hard drive.
If you have additional files that you wish to keep, backup those files first, then you can add them to your recovered hard drive.
Hope this helps.
Oct 22, 2010 | Microsoft Computers & Internet
I cannot find the music that i put on the v touch from the computer but my library says all songs have been added but i cannot find them on the v touch SO WHAT AM I DOING WRONG THIS IS A V-TOUCH THAT HAS...
Putting Files on Your Player
  1. Plug in your official Visual Land mp3 player to your PC with the included USB cable.
  2. Locate your player on the PC by opening 'My Computer', it should show up as an extra drive. Open the player drive.
  3. Locate the directory where the files you want on the player are located on your PC, and open that folder.
  4. Click and hold on the desired file to transfer, and then "Drag" it over to the player's external drive folder, and unclick to 'drop' the file onto the player.
  5. Your Visual Land Player may support synching with Windows Media Player, but it is not guaranteed. Your Visual Land Player however will NOT support other synching software such as iTunes, MusicMatch, or any other programs. Simply use the process above to put files on your unit.
If your Songs Not Showing in Playlist
If your songs are not showing up in the playlist after updating it, try removing any subfolders within the MUSIC folder.
The V-Touch Player uses a directory structure for initial scan of usable files. Each mode goes to an appropriate default folder for its initial scan of playable files. Video files should be placed in the “VIDEO” folder. Audio files should be placed in the “AUDIO” folder. Image files should be placed in the “IMAGE” folder. If they are not placed in the appropriate folders, you will need to search through the player's directories to find them.
Apr 13, 2010 | Visual Land V-Touch Digital Media Player
Music in music library shows corrupted cannot delete
Connect ur phone to ur PC in Data transfer mode.
Make sure u can view hidden files in ur pc.
Open E:\private\
where E: is ur memory card drive name
Delete all the files in "private" folder.(u can copy and save all the files before deleting incase anything goes
Disconnect ur phone and restart it.
Open music library it will refresh itself automatically.
Mines working fine now....
Nov 18, 2009 | Nokia 5800 XpressMusic Smartphone
I have a 1 terra bit external hard drive . I edited music from a pc to my external hard drive using cd's & lps. I've been having problems with putting my music library in my new laptop computer. One...
Your installed music library in your external hard drive might not be supported by your media center on your new laptop, try to convert the files where the software are supported by your media player. try convert Master software, you can download it free then convert your files
Nov 01, 2009 | Seagate Free Agent Go Small 12 GB USB...
Iriver won't let me upload from CDs and transfer....
Best way to use the H10 20gb is by creating a directory on your hard drive with your desired mp3 format files. Use ripping and encoding software with your existing audio cds.
Connect the h10 to the PC via the UMS trick (see this website).
Using a file directory on your pc, drag and drop the mp3 files from your pc to the MUSIC file folder on the h10. Install and run the EASY10 playlist creator software on your pc to organize the new files on your iRiver player. Disconnect the USB connection and enjoy!
Mar 22, 2009 | iRiver H10 MP3 Player
How do i delete songs off of my mp3?
Hi there. There are 2 ways to delete songs from your Sansa E260: By browsing the folders containing the songs, or by formatting the player. To browse the player, it's important to know first that the player has 2 modes: MTP (Media Transfer Protocol) and MSC (Mass Storage Class). Music files saved on one mode would not be seen in the other mode when browsed through Windows Explorer. You can switch modes by navigating your E260's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E260 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E260" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player I hope this helps. :)
Apr 21, 2007 | SanDisk Sansa e260 MP3 Player
Archos 605 WiFi Digital Media Player Logo
159 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
