Question about Refrigerators
Unit stopped cooling
I hear a click and humm for a few seconds every few minutes.
  • 410 Answers
The click and hum your hearing is most likely the compressor trying to start. the most common problem is a bad start relay on the compressor. in rare cases the compressor may be bad. if you are mechanicly inclined youc an replace the relay yourself for less than 50 dollars. you will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company. good luck Peyton
Posted on Mar 11, 2009
  • 163 Answers
Replace your relay and overload on compressor.you can replace most with a 3-n-1 hard start for ref. compressors.easy to install and cheap repair.
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Switch on fridge and compressor runs for a few seconds and then stops, switch off for a few minutes and then switch on again and it runs for a few seconds. Checked thermostat and seems to be OK
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | AEG Refrigerators
Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
www.appliancefactoryparts.com/content/.../118816.pdf - United States
Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
I suspect, your thermostat may have a faulty sensor?
factoidz.com/troubleshooting-your-air-conditioning-thermostat/
http://www.inspectapedia.com/heat/Thermostats.htm
Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Refrigerator stoped cooling
Ok, if the unit compressor will not run and just clicks on and then off, this will confirm a low charge state ad you will need to recharge this unit. the refrigerant level is low.
Purchasing a recharge kit and recharging the system will fix this issue.
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer not freezing on m,aytag mfd2560hes
hi andy, based on your story, i think the humming sound is coming from the compressor trying to start and the clicking sound is when the overload trips and make that clicking sound to turn off the compressor but it does resets itself so it would humm again after a few minutes and tripps off again..try to unplug the unit for a day to cool off the compressr and then plug it back. if it will happen again, you need to replace the compressor. i hope i was able to help..
Jul 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
