Question about Emerson Microwave Ovens
When i use my oven there is an arc from the door to the body in about 7 different spots. sometimes it is enough to weld the door shut. What can i do it is only about two years old.
    Problem Solver:
  • 11 Answers
The basis of the claim "you cannot put anything made of metal in a microwave" is based on the fact that metal:
a) reflects microwaves;
b) it will acquired a electrical charge that can arch to the grounded chassis.
Somehow, your door is no longer grounded to the chassis and so, gets a charge that arches to the chassis. Check the door for conductivity to the chassis and ground to the chassis any part of it that is currently insulated.
Posted on Mar 11, 2009
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
It lights up but the buttons won't work, what is wrong with it?
Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. If the magnetron was making louder noises prior then replace the magnetron. the giant capacitor could be bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Jun 12, 2013 | Emerson MW8778 Microwave Oven
Ny microwave is arcing up by the stirrer motor even after the motor is disconnected
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may also have to replace the capacitor. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Feb 26, 2013 | GE XL1800 1100 Watts Microwave Oven
Problem with the Whirlpool GH5184XPQ 1100 Watts Microwave Oven: In turning the microwave on this morning, a faint electric sparking was heard. Upon shutting it off and opening the door an acrid burning...
The problem is that the magnetron is arcing when it is running and it has found a couple bare spots 'exposing the metal'. The microwave uses a special industrial white enamel paint to prevent arcing, it is very important that the oven be removed from service until the situation is rectified otherwise there is a danger of shorting out the magnetron.
Feb 22, 2011 | Whirlpool GH5184XPQ Microwave Oven
Frigidaire 7G53402944 Spot weld on door hingle bracket failed
Try a Pop-Riveter, drill small hole insert rivet and squeeze handle.
Feb 26, 2010 | Microwave Ovens
My whirlpool microwave will not heat. Model no gh6177xps-4. was working last night.
Did you search this site for this problem? I have posted a answer to this site several times.
My response is please check the door safety interlock switches. These switches fail because we (count me in the number) open the door while the oven is running. Eventually, they arc enough and fail. When they fail, the oven doesn't know the door is shut and will not turn on the magnatron. Forget what you know about the door. The oven needs to know.
Thanks for your interest in FixYa.com
Jan 20, 2010 | Microwave Ovens
Everything works on my microwave oven but it doesn't heat the food
Check the door safety interlock switches ...
Remove the cover and find the switches opposite the hinges. Check with a contunity meter.
If you open the door while the oven is cooking these switches arc. Enough arcing and they burn. When they are burned, they cannot tell the oven that the door is closed. When the oven thinks the door is open, it will not turn on the heat.
Oct 09, 2009 | Whirlpool GH4155XP Microwave Oven
Arcing at door
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Jun 26, 2009 | Whirlpool GT4185SK Microwave Oven
I accidentally covered a plate with foil in the microwave. there was Arcing (no fire) and now there is black marks etched where the foil touched the sides. The cavity seems unharmed though, it seems if I...
Sometimes the arcing itself will cause black marks inside the oven. The places where the foil was melted, (touching), likely left small metal deposits, possibly now, impregnated in the surface. It is important to remove these if possible to avoid further arcing. Remove these then test to make sure the oven is functioning properly. If so, continue to use.
Jun 22, 2009 | LG LRM1260SW Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
