GE EasyCam Pro Personal Web Camera
Problem for GE EasyCam Pro Personal Web Camera
I don't have the install cd for my GE easycam
By linp90 on Mar 11, 2009
I don't have the install cd for my GE easycam Pro....is there a way where i can still install my webcame onto my comp without the cd
Same Problem
Apr 09, 2009
-   same here-   Guest
Solution #1
posted on Sep 23, 2009
Not Rated)
B18bSiHatch
Rank: Master
Rating: 88%, 9 votes
yep. you just need the device driver. it can be found here
http://www.jascoproducts.com/support/software-downloads.asp#pccams
scroll down to the PC Cams section and you will see driver links for both the easycam and easycam pro.
Was this helpful?
Yes
No
Solution #2
posted on Sep 15, 2009
Not Rated)
tech240
Rank: Wiz
Rating: 81%, 21 votes
yo should be able to download the software from the web and make it work without a cd.
Was this helpful?
Yes
No
Solution #3
posted on Aug 29, 2009
Not Rated)
senislt
Rank: Apprentice
Rating: 0%, 0 votes
You can found driver in www.driverguide.com
Was this helpful?
Yes
No
Solution #4
posted on Aug 15, 2009
Not Rated)
bschilz
Rank: Guru  Computer Accessories  Expert
Rating: 88%, 579 votes
Here's a link to the driver and owners manual.
Choose 98064...that's your webcam.
This is Jasco's website. They provide support for GE.
Was this helpful?
Yes
No
Solution #5
posted on Jul 13, 2009
Not Rated)
contactpvn
Rank: Guide  Computer Accessories  Expert
Rating: 100%, 2 votes
Yes you can still install your WebCam by downloading the drivers/softwares from the internet. Download the software drivers from the following website. Find the software under PC Cams Section.
Was this helpful?
Yes
No
Solution #6
posted on Apr 30, 2009
Not Rated)
yooperbud
Rank: Wiz  GE Computer Accessories  Expert
Rating: 82%, 2036 votes
Normal 0 GE PC Cam Drivers
Then
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Comments:
May 15, 2009
- Normal 0 GE PC Cam Drivers
Then
A. Skype Setup:
B. Yahoo Setup:
Jul 01, 2009
Then
A. Skype Setup:
B. Yahoo Setup:
Aug 21, 2009
- Copy this web site and paste it in your web browaer to get the GE PC Cam Drivers
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
Images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Sep 13, 2009
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Sep 17, 2009
A. Skype Setup:
B. Yahoo Setup:
Microphone
Speaker
Camera
Notes:
Was this helpful?
Yes
No
Popular Solutions for GE EasyCam Pro Personal Web
Questions and Unsolved Problems for GE EasyCam Pro Personal Web
Do you recommend GE EasyCam Pro Personal Web Camera?
Answer
Answer
I went to this site and tried to download the software. Everytime it says there was an error. I... (More)
Answer
i tried installing the software on vista but the program will run but the video and sound will not... (More)
Answer
i just tried installin my cam, its the 98756 model. everything worked fine till the end. says it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE EasyCam Pro Personal Web...:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14846
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
